Pro-106: Cloneing
R
retiredmich
Guest
Can I use my RS PRO 106 to clone a WS 1040 aren't they the same ?
Spitfire8520
Might be slightly less clueless! =)
Colorado
Yes.
Whistler WS1040 Owner's Manual said:
Scanner Cloning
If you have access to a compatible scanner that is already programmed for your area, you can transfer that scanner's programming using a standard stereo patch cord (not included), terminated with 1/8” male stereo plugs at each end.
The WS1040 is compatible with the following scanner models: PRO-106, PRO-197, PRO-651, PRO-652, GRE PSR-500, PSR-600, WS1040, and WS1065.
R
retiredmich
Guest
Can I clone Firmware from a RS PRO 106 to another 106 ?
R
retiredmich
Guest
On this firmware up date for RS PRO 106 where do I get this firmware & this is something I can do my self ?
DickH
If you put PRO-106 Firmware in your search box you will find it.
