Coax cable ?
k8niv
Have a question, as the coax cable will run under ground, how deep would the trench need for the pipe to lay in ?.....
And on the antenna side, should I take this coax all the way up to the antenna, or put a break in the coax where it comes out of the pipe, and up to the antenna ?..........always concerned about the weight of the coax pulling down on everything...
I'd like to think this coax would never need to be replaced, .......
Deep enough that it won't get hit by something. Code doesn't really have anything on low voltage communications cable, at least that I recall.
I'd say go down as far as you safely can/easily can and call it good.
I have one I ran down the side of my house into the back yard. I think I went down 18" or so. It's not in a location that it'll get hit by anything. 18" was as far as I could easily get without breaking my back. I did it all with pick and shovel, so I'm happy with it.
If its a direct bury rated cable, it'll have a gel filling. Running that up vertical really far can result in the gel slowly oozing down the cable and pushing it out the lower end (probably in your shack).
I'd terminate the cable at the base of your tower/mast, a few feet up out of the ground. Put it in a PVC terminal box. Transition to a regular coax. That also gives you an excellent point for putting in a grounding point on the coax. You ideally want the coax shield grounded at the base of the mast/tower, and that'll be an easy place to do it.
Support the cable well along its vertical path. At the antenna, make a loop so the connector isn't under any stress.
Done right, it shouldn't be an issue. I've got some runs of 1 5/8" Heliax that have been up since 1994. They still sweep just fine and show no signs of deterioration. Most important part is to make sure you properly weather seal all the outdoor connections, and you should be golden.
Industry standard weatherproofing tutorial:
MUTNAV
Don't forget with digging comes the possibility of hitting stuff (gas,water,electric, septic).
Joel
K7MEM
Swartz Creek, Michigan
Yes. In my area (Just south of Flint, MI), all services (gas, electric, cable TV, invisible fence ) are under ground. A quick call to the county will have someone out to mark all the services. They have been to my house about four times so far. Any contractors doing work on my property will also call the county. Luckily, at my house, everything is in the front/right side, so the back yard is completely clear.
Hand digging is usually safe, but if you are going to use a machine, you absolutely want to call 811:
You use white spray paint to mark your proposed excavation.
The local utilities will come out and spray pain all their services in the area.
If you do all that, and still hit a utility in your excavation area, you are not at fault.
But, going down 18 inches or so isn't likely to be an issue. Generally utilities -should- be buried much deeper.
