K7MEM
None of your questions have simple yes/no answers. There are too many conditions that apply. That is why I linked to the article by M. Walter Maxwell, W2DU/W8HKK, in my original post. Especially good reading is on page 11, which lists 27 true statements about antenna matching and SWR.
In general, yes, the length of the feedline should not matter. If changing the line length changes the SWR, then there may be something wrong with the installation. This could indicate poor connections, antenna currents on the outside of the feedline, insufficient ground, etc.
Assuming all of the connections are good, it shouldn't matter where you check the SWR. But there are several conditions where, measurement from the radio end can lead to false readings.
For example, long lengths of high loss cable will attenuate the power getting to the antenna. But it will also attenuate any reflected power caused by a mismatch. Because SWR is based on forward and reflected power, the reduced reflected power may make your SWR look better than it really is.
Martin - K7MEM
So basically for a single mobile ant, all that is needed is whatever length it takes to get from the radio to the antenna? Correct?
Also is it better to check SWR at the antenna or the back of the radio?
Martin - K7MEM
