Codeplug from Apx 8000 to 6000
D4chaplain
So I did note the power levels and adjust. I figured out the issue. When I would drag the trunking part over, it threw the error due to no SK in the 6000 CP. so I uploaded the SK and did it again in which it transferred all the control channels and so forth. Changed the unit ID and now working like a champ. Thanks for the help all.
WRTF671
I have had good luck with import export but I have found that sometimes doing the import in stages is helpful. Import only the conventional personalities, then the channel/zones, then the scan list. This saves a lot of manual correction on pointing scan lists/personalities at each other. Granted I work for a railroad and nothing is trunked so this has been with conventional only.
