Computer windows 95 98 program spectra or saber
kb5vai
What is the fastest computer that you can prohram a spectra and saber with using windows 95 or 98 version software?
cmjonesinc
I use a toughbook cf-18 mk5 with an Intel Pentium M 1.2GHz processor. I've never had an issue with it being too fast on either of those radios. I do however just use a flash drive with dos on it and not win 95 or 98. My toughbook cf-19 mk3 with the CoreTM 2 Duo 1.2Ghz does have some issues with some older motos but not many that I've tried.
rescue161
KE4FHH
Hubert, NC
You HAVE to boot into REAL DOS. You can use the Win 95 or 98 DOS.
No matter how many times you repeat this sound advice, people will continue to open up a DOS prompt to run the RSS and wonder why they can't communicate or worse, end up bricking their radio. I guess it's because they want to use a mouse? Or is it that they just don't know the commands to type to navigate in DOS? The only radio that I had problems with using a faster computer was the Syntor X9000. Kept an old 486 for that one.
kb5vai
Is this the same for the windows software? Have a 486 with windows 95. Trying to install with backpack cdrom, get error installing.
I thought i rember reading a 386 sx 25 was the fastest you were supposed to use.
6079smithw
Near the Biggest Little City
I thought i remember reading a 386 sx 25 was the fastest you were supposed to use.
95 can be iffy on some 486 machines. You're better off with 98SE IMHO. I have it running on a K6 400 mHz and a Pentium II clocked down to 350 mHz with no problems. All with gen-you-wine serial ports of course. Good results with both OEM Moto RIB cables and a couple of Chinesium RJ-45s for Radius mobiles. YMMV, good luck.
a417
I've had 95 on to a Pent II - 233 w/o an issue. It was highly contingent on the mobo chipset, IIRC.
Project25_MASTR
Millennial Graying OBT Guy
Texas
The Comtegra CPS doesn't like faster stuff.
kb5vai
And would win. Though do have a regular spectra. But yes mainly astro. Sorry for the fighting. Yall figured it out thoygh.
kb5vai
So, theres a difference in programming requirements of astro saber and spectras?
