SDS100/SDS200: Constant Beeping
JobabeBob1981
Cornwall NY
Volume will not stay as set, constantly fluctuating up and down with a beeping sound on my SDS100??
Ubbe
Stockholm, Sweden
With each volume change it will beep, so you have a bad working selector switch, as many others have experienced. It's probably that infamous connector between the circuit boards that are badly soldered. It can also by the rotator switch itself that can be fixed by some contact spray, but has to be done from the inside as the outside have a water tight seal. Or let Uniden fix the problem for $90 +shipping.
/Ubbe
JobabeBob1981
Cornwall NY
/Ubbe
Thank you
