TRX-2. Is it possible to program in the TRX-2 only the control and alternate frequencies in the 453 Mhz and 460 Mhz range (Onondaga and surrounding 2 counties)? Thank you for any advice offered.
YES, if it is a P25 system.TRX-2. Is it possible to program in the TRX-2 only the control and alternate frequencies in the 453 Mhz and 460 Mhz range (Onondaga and surrounding 2 counties)? Thank you for any advice offered.
Yes! It is all P25....YES, if it is a P25 system.
Ah! I did not know this! Thank you!Under Site Options, Trunking Tables must be set to Auto Fill.
I should have said if a site is a combination of 700 and 800, Auto Fill must be used.If a system is a combination of 700 and 800, Auto Fill must be used.
