Corpus Christi P25 System New Towers Active
autoair
IT Technician
Corpus Christi Texas
I heard the techs working on the system are still trying to design it. Not sure if it is true. But makes some sense if systems are going on and off.
scanthewaves
Texas
This may sound like an odd question but why are they switching, is the EDACS system inadequate? Looking at the coverage of the new towers it seems that the EDACS system with its towers has better coverage than the new system, unless there will be more towers? On a related note, are there more frequencies for the Flour Bluff site? All I see is one and it’s a control channel. If I recall correctly EDACS needs more than a control channel?
nd5y
Wichita Falls, TX
Harris discontinued support for EDACS in 2017.
If the database only shows one frequency and it's marked as a control channel it probably means nobody has submitted the rest of the frequencies.
ralexander5
Mathis, Tx
I caught the following on the Flour Bluff site using DSD plus. Signal was weak at time and could not confirm the first freq so did not submit. The others match existing EDACS
Site: 3.3 NAC=00D ; Flour Bluff
Neighbor: 46FEA.169-20.20 ; Shoreline
Channel 0-21: 851.275 SCC
Channel 0-88: 852.1125 CC SCC
Channel 0-193: 853.425 CC SCC
Channel 0-226: 853.8375 CC
ralexander5
Mathis, Tx
Brooks County has a new application for system that that appears to be a part of the Coastal Bend System. I caught the Encino site 53 twice now with skip coming in from the south. A site in Falfurrias should also be coming on-line. Will submit to database when license is issued.
Encino
Network: 46FEA.055
Bandplan #0: Base=851.0125 Offset=-45 Spacing=12.5 BW=12.5
Bandplan #8: Base=851.0125 Offset=-45 Spacing=12.5 BW=12.5 Slots=2
Site: 53.53 NAC=03D
Channel 0-272: 854.4125 CC
Channel 0-408: 856.1125 SCC
Channel 0-446: 856.5875 SCC
Channel 0-480: 857.0125 SCC
rattlerbb01
TX/LA Database Admin
Boerne, Texas
Encino
Network: 46FEA.055
Site: 53.53 NAC=03D
If it’s online and you can confirm where the signal is coming from we can still add it since it is on the air. We can add the license later.
