Custom alert tone problems
tcfcGreg
Hey guys just like the title suggests, my g5 has recently stopped playing my custom/pre loaded alert tones. Is their a setting I should double check to verify and make sure it’s checked somewhere? I haven’t programmed it through the pps software in quite a while
K6LEH
Oakland, CA
Have you tried rebooting it? Hold the two side buttons and the top playback buttons?
JD21960
ILL-annoyed
It's obvious the PPS settings for your "custom" tone need to be looked at. Wherever you installed the custom tone for whatever talkgroups? review that in tab #4
krokus
Southeastern Michigan
Two KISS questions:
1) Are you sure no one else has programmed your G5?
2) Are you sure the TG with the custom alerts were sent?
tcfcGreg
Two KISS questions:
1) my g5 hardly ever leaves my side... and there’s a password on it so it can’t be reprogrammed.
2) my screen lights up the colors I have set when the tones get dropped for my different companies red/green, and the g5 plays the default alert tone in your pps.
