Delaware County Pa New System
Whiskey3JMC
NI NI NI
Simulcastylvania, TE
Was power cut to any sites just now? Earlier today & this week I had full signal reaching up to Montco. Now zilch. I know it's definitely not my setup as I have the same pick up on Philly & NJICS as I usually do...
stevecast2024
And for the notes, automated dispatch has moved from Command TGID-200 to its permanent talkgroup, TGID-160.
@stevecast2024 When will TGID-224 (PD County Dispatch) be used as opposed to the sector channels, for BOLOs and such?
County is what the Park Police use for their daily operation. They use County on today's system as well but not many folks monitor it.
portroyalbirdy
Central PA
This may have been asked already, and if so I apologize for re asking, but will the Kenwood/EF Johnson radios on the Delco system be able to be used on Chester County's Harris system and vice versa, or will each mutual aid partner need that systems branded radio?
policefreak
Berlin, NJ
So the way any P25 system works, including the Delaware County and Chester County P25 systems is that any P25 (Phase 2 in this case) capable radio, no matter the brand, should be able to operate on the system.
portroyalbirdy
Central PA
I figured they COULD, with the P25 thing, but didn't know either counties stance on the matter.
cavmedic
Pottstown Pa
If my memory serves me, there was NOT a restriction on radio type as long as it met the minimum requirements. One thing I have found is that Delco does not play those games when it comes interoperability with neighboring counties or agencies. No one has time for that nonsense.
rgchristy
Delco, PA
Out of curiosity, is there any reason why it comes in loud & clear on my SDS200 and not at all on any of my Whistlers? I have my TG wildcard activated.
I'll try to program in TGID 3 to see if it changes anything.
Whiskey3JMC
NI NI NI
Whistlers particularly are prone to it...
That's worse than getting an REO Speedwagon song stuck in your head...Apologies to all REO Speedwagon fans out there...
♫ I can't fight this sim-ul-cast any moooore...♫
An original REO Speed Wagon:
policefreak
Berlin, NJ
As much as I like the design of the Whistler, the SDS Scanner is a far superior receiver on P25 simulcast.
rgchristy
Delco, PA
It's weird. I listen to the new system all day long on my Whistlers and Unidens, but for some reason TGID 3 with the tone was not received today on the Whistlers. The tone was blasting away on my SDS200, but my TRX-1 & TRX-2 were deaf. Everything else came through fine.
I'll check my programming tonight.
policefreak
Berlin, NJ
Hmm. Is it some kind of weird patch?
