Delaware rebanding
de784
Delaware
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 4.1.1; en-us; HTC6435LVW 4G Build/JRO03C) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Does 600 do digital
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you mean the PSR-600 the answer is yes. And the same software you used to get your PSR500 going will work with the 600 too.
HTH...Mike
robertson40
Member / Delaware Breaking News DE110
Dover Delaware
A good resource has told me tht kent county as switch all control channels to the new cc's today around noon just a fyi
robertson40
Dover Delaware
Audiodave1
Chadds Ford, PA
Yep, Looks like the lower 3 channels + the CC have switched over. This is the same way they did it in NCC, A few channels at a time.
Audiodave1
Chadds Ford, PA
Hmmm,.,..that's an alternate CC and is in the rotation according to Trunk88 and Unitrunker.
Also, the new channels are much higher RF level into NCC. Easily 6dB more...or my yagi is that much more efficient (better tuned) 15Mhz lower.
Looks like 852.65 is the only active voice channel for tonight.
robertson40
Dover Delaware
Now for some reason all 3 of my hp-1's aren't working at all with the new controls channels anyone have any clues or tips
bs369
Kent Countly, DE.
DE rebanding
Just upgraded my HP-1 with the 6-2-13 data base. Is it safe to assume that it containes both the new Kent and Sussex freqs?
I don't have the extreme upgrade so I can't check the actual freqs installed or can I?
Audiodave1
Chadds Ford, PA
What you see in the Delaware database will be what is in your radio. I don't think you can look at the frequencies on the radio....But can if you dig into the memory card but that's a whole other discussion. I suspect when you power up it'll just work.
Dave
bs369
Kent Countly, DE.
DE rebanding
Thanks, Dave. I'm going to stay out of digging into the card. I'll leave that to others. HP-1 seems to be working just fine since the up upgrade.
Bob Schweikert/N4NMK
Harrington
