Difficulty decoding cap codes for FD toneouts. Are they something else?
cquinn3
[Here] is a list of fire departments in Orange County, NY and their paging tones. They use Quick Call II. I've taken recordings of toneouts and used Audacity to confirm that these frequencies are still accurate.
I have some documents from the dispatch center which look like this:
There is a document like this for each department. Each document lists a three digit "Alarm Call" and a four digit "Home Alert," which I assume are cap codes. I tried decoding them with [this guide] to see if they matched the frequencies listed above, but I was having some issues.
I tried decoding the "Alarm Call" with the "General Encoding Method (3 Digit Cap Code)," but the tones I got don't match the listed tones above.
I'm not sure what method to use to decode the "Home Alerts." The "Metro-Page/Centracom System Method" is the only listed method which produces 4-digit numeric cap codes, but it doesn't seem to be the correct method. Coldenham FD, for instance, has a Home Alert of 5395, but [this table] seems to suggest that a cap code can't start with 53.
Here are some more departments along with their Alarm Calls, Home Alerts and paging tones.
DepartmentAlarm CallHome Alert[Siren] A Tone[Siren] B Tone[Pager] A Tone[Pager] B Tone[Pager] C Tone
Bullville6794427532.5697.5153017431036
Campbell Hall4531207907.5817.5524.6953.71082
Chester4075106667.5532.51930.2726.8977
Circleville2305301832.5652.51930.21122.51326
Coldenham2175395607.5517.5268812321130
Cornwall-on-Hudson2942365667.5562.595012321130
Cronomer Valley4962494622.5952.5103615981743
Cuddebackville4211336772.5712.564312871430
Florida2031210652.5832.5589.7799732
Fort Montgomery4161325712.5952.5615.812321598
Goodwill4471390862.5532.579910821232
Goshen6282410772.5562.5810.21433.41669
New Windsor4401150862.5667.5707.3524.6646
Am I just decoding the cap codes incorrectly? Are they even cap codes or are they something else?
cquinn3
The dispatch center uses the Motorola MCC7500 dispatch console if that's of any significance
dave3825
Suffolk County NY
I have always used Pano tuner ( Android and Apple ) and matched up to closest on the chart @buddrousa posted.
What are you actually trying to do? Validate the info in the Wiki or program a scanner or pager? I also never saw C tones before but all I have is Uniden scanners that only allow entry of A/B tones.
DaveNF2G
Latham, NY
It seems possible that the dispatch center's designations for paging are the codes to be entered into their console to access the various tone combinations and have no numerical relationship to the audio frequencies of the tones.
When I dispatched for Monroe County, we entered 4-digit codes into a keypad that were mnemonically related to the agencies' numeric designators and the particular response being requested. For example, a code like 4511 would be 4th Battalion 5th Department (Gates) fire call. The actual tones sent were a combination of QCI and QCII, plus a few Plectron, at the time.
cquinn3
I’m mostly just curious about the meaning of the Alarm Call and Home Alert. If they’re not cap codes then I wanted to see if anybody had any ideas of what they could mean.
If they are cap codes then I’d like to find out what encoding method / tone set is being used. Again, part of it is just curiosity, but I’d also like to see if I could use it to verify the exact tones on the wiki.
All department pagers are set off by the A/B tones and chiefs’ pagers are set off by the A/C tones. I don't know why the wiki calls it a C tone. I guess it would make sense to organize the list like this:
A ToneB Tone
Bullville Page15301743
Bullville Chief Page15301036
Bullville Siren532.5697.5
Cambell Hall Page524.6953.7
Cambell Hall Chief Page524.61082
cquinn3
Thanks a lot! Looks like “Alarm Call” is the GE 99 encoding of the siren tones.
The pager tones look like Plectron format tones. I’m still trying to figure out how to get the tone values from the “Home Alert” code (assuming that they’re related and Home Alert doesn’t mean something else).
The bottom of the Plectron Format Tones table says “Plectron does not employ code groups - Random selection only.” Does this mean there aren’t standard cap codes for Plectron tones and that they’re randomly mapped in the console like @DaveNF2G suggested?
I also found this table. Could it be part of the encoding somehow?
k2hz
Rochester, NY
Going way back, I believe Motorola radios that supported QCII allowed you to program A, B and C tones. The radio could then be programed to respond to both A/B and A/C and either or both B and C could be "long tones". C was commonly used if the "long tone" was not the same as the B tone.
Dave520
Connecticut
There is an old phone app called Radio ID that I use sometimes. Just hold it up to the speaker on your computer and it will show most paging tones. Just realize that this app has not been updated in many years but still does what it originally was designed to do.
Thanks,
Dave
GTR8000
NY/NJ Database Guy
BEE00
Orange County hasn't manually entered paging codes for decades. Everything is hard-coded into the consoles and has been for decades. This is especially true since 2019 when the new consoles and ASTRO 25 core came online.
GTR8000
NY/NJ Database Guy
BEE00
Orange County hasn't paged from single towers in a number of years. When the ASTRO 25 core came online in 2019, FD and EMS paging was converted over to simulcast for each.
GTR8000
NY/NJ Database Guy
BEE00
Correct. Motorola still refers to it as A/B/C/D tones, which correspond to a "slot" for each tone. Way back in the day these were physical slots on Minitor pagers for the tone reeds/filters, literally labeled A, B, and C (D came along later but wasn't an option on early series Minitor I and II pagers). There were various formats that you could achieve with the use of jumpers or later on software settings. A-B/A-C were most common, you could also have a Long B or Long C tone, or a less common A-B/C-B setup. Once all of the pagers and radios were synthesized, the "slot" names became more or less moot, but the terminology was retained. Even the very latest APX series still refers to A, B, C, D for QCII paging.
Mbk127k
Hudson Valley
All department pagers are set off by the A/B tones and chiefs’ pagers are set off by the A/C tones. I don't know why the wiki calls it a C tone. I guess it would make sense to organize the list like this.
Because back in the day when many departments in Orange County used pagers that had Tone reeds it would be A/B slot and their would be an option for a 3rd Tone Reed for the chiefs/officers page which would be A/C. I don't remember what year it was they started utilizing it maybe around 2010 but Orange County didn't use to have Long tones for the Battalion's and they also never had a County All Call either nor did they have Tech Rescue tones or Battalion 8 water rescue tones either.
I believe majority of the tones in the County are plectron tones. There are also some departments that replaced some of their tones so the wiki may not accurately be correct such as Orange Lake siren Tone is different from what it use to be and Tuxedo siren Tone (Tuxedo use to have like 3 or 4 Tone sets for a call to set off the individual stations sirens). Also EMS Tones have changed a lot over the years if you are looking at them as well, like Montgomery EMS never had all call tones just duty tones, Newburgh EMS has quite a few that they use to never have and even Wallkill. They don't even select towers anymore to page off of, all simulcasted.
Also what you have there is part of the Dispatch Notes. Here's Maybrook FD notes.
