MacombMonitor
- Joined
- May 18, 2005
- Messages
- 3,551
- Reaction score
- 4
Ok, now it's starting to sink in!
Thanks guys!
Thanks guys!
joey_corleone82 said:oh btw, I ordered the ASCANC and the 821-896Mhz tuned PHANTOM they should be here today. I'm going to experiment, but I would have to imagine that the PHANTOM tuned for specifically 800mhz band will outperform the ASCANC significantly on that particular band...and monitoring MPSCS and 800mhz digital is alot of what I want to do, so thats the whole reason for this mess
- Joe (kd8bxf)
kb2vxa said:Nominal bandwidth;
Low port 120-600MHz 1dB down @ 600MHz
High port 800-900MHz 1dB down @ 800MHz
Crossover @ 700MHz
Insertion loss 0.75dB
Available in 50 or 75 ohms impedance
Connectors customer specified
Tin Lee Electronics Ltd. Toronto Canada www.tinlee.com
Link to page http://www.tinlee.com/Diplexers.htm#Table: Standard models LH7 and Order Information
Once you have sussed it out as I have you may enquire of sales;
Mrs. Sneva Lee, E-mail: sneva@tinlee.com
This is still a work in progress and so far the best lead I have.
Simon,SIMON11 said:I have no technical knowledge on this subject. But out of interest I bought a passive diplexer and I found it no better than using a bnc tee on the scanner. The instructions with the unit do say though that it may need at least one of the antenna to be powered from a mast amp to boost the signal. I am now thinking of buying a mast amp to try it out.
At the moment I use the bnc tee on the scanner and I can connect either or both antenna as I wish. Some frequencies have a slight benefit others are weaker.
RISC777 said:Simon,
Did you look at these? http://www.universal-radio.com/catalog/preamps/0973.html I'd like to know myself if you used those specifically or other (please).
MacombMonitor said:Where are you in Michigan? There are so many towers, I can monitor MPSCS on a stock rubber ducky inside my SUV, with the hand-held sitting in a cup holder, down on the floor.
Bill
joey_corleone82 said:MacombMonitor....I'd love to know where you are monitoring from to get that kind of performance on MPSCS!
MacombMonitor said:To be honest, there are a few things in my favor. Where I live, I have several towers all around me. I monitor Mt. Clemens, Romeo, and Richmond. Also, in Macomb, there are not a lot of tall buildings. My vehicle is a Saturn VUE, which has all plastic side fenders, and door panels. Most I my driving is in the vicinity of those towers.
If I drove the same route you did, I'm certain I'd have the same problem.
Just to rule out problems with your antenna system, try putting an RS800 rubber ducky directly on the back of your radio, (using a BNC 90 degree adapter), and sit it on the top of your instrument panel with the antenna near the windshield. See how that performs.
Bill
kb2vxa said:Hi again,
"But out of interest I bought a passive diplexer and I found it no better than using a bnc tee on the scanner...Some frequencies have a slight benefit others are weaker."
Simon, that's where you contradict yourself. You're experiencing the same problem as I was, see Al's post for an explanation of phase reinforcement and cancellation. Simply put, those stray signals I mentioned are in some cases reinforcing ("benefit") and in others cancelling ("weaker") with the tee and in my case the combiner. If you didn't notice any improvement with the diplexer you weren't paying close attention to signal levels or were using the wrong diplexer.
Simon, that's a splitter with a fancy label. If you can make a diplexer with resistors and capacitors, I must have missed that day when I got my degree. Capacitors and coils, yes, but not capacitors and resistors.SIMON11 said:There are only a few capacitors and resistors in the whole thing. I take your point and it probably is the wrong diplexer.
