DM1600 Mobile Radio Programming - No sound on simplex calls
Roditu
Hi, I'm very new to Motorola radios in general. I'm trying to program a DM1600 radio I have with a simplex analogue channel, but I'm having some issues. I can transmit with the radio fine to my handheld, but it's almost as if the speaker is muted when receiving. The receiving green LED is on and I can see the radio gets a signal, just no sound.
I've also done transmissions through a repeater, and that works fine, meaning that the speakers are not the problem.
This is the config file I'm using. I'd really appreciate any help.
  • config1.zip
FKimble
Newnan, GA
Sounds like you that it set up for a tone to receive. Either add the tone to the other radio or turn off the receive freq tone.
Frank
Roditu
Hi Frank, thanks for the response. Do you mean TPL? If so, I've done the same for both radios.
