Dmr codes for Ouachita county
chidester
chidester,ar
How do you find the color codes and repeater slot for the Dmr radios in Ouachita county,they are not listed in RRI bought a md-380 to listn to them and have a little luck hearing them
INDY72
Indianapolis, IN
Use an DMR capable scanner, or SDR and DSD+, or DMRDecode etc.... Once you know them, please submit them so we can add them to the db. TY
poppafred
North Central Texas
I would suggest using an SDR receiver and DSD+ with SDR#. The newest versions are very easy to install and the SDR dongles are cheap from eBay or Amazion.com. and are always a bit fun to tinker with on other transmissions. I got mine from eBay and it covers HF, VHF, UHF and up.
I used the local weather service transmission to find my correction for frequencies and RR for the frequencies to listen on. There is a new DSD+ add-on for SDR# that is even simpler to use.
Once you are set up there is no need to do anything else but listen and note the color codes & slots
chidester
chidester,ar
dmr
I just bought a couple of sdr dongles have not set them up yet but when I do .I will send the info when I get it
