tnystwtfn
I need 3.8 bin, can somebody please send to me
Eric:
Thank you for the hard work of creating the tool. My PSR800 now thinks it is a WS1080 an I am hearing DMR. I am very happy. Thanks also to the person who sent me the dropbox link.
Please don't think I am ungrateful, but is anyone working on getting the Whistler NXDN upgrade to work on the PSR radios as well? I am a railfan.
...is anyone working on getting the Whistler NXDN upgrade to work on the PSR radios as well? I am a railfan.
Hello,
Unfortunately, NXDN is a mode too far. The TRX series uses a bigger flash memory space, so even if the existing firmware could fit, the base, or starting, flash memory address is different. I feel that it is for the best as well, as it would cut into sales of a current product, and likely cause more problems. There are enough problems dealing with outdated firmware as it is, likely due to Whistler watching threads like this one. Imagine the fury if NXDN on the WS-1080 was possible.
I only consider this an interesting experiment and not really mainstream. Save up your pennies for a TRX-1. The TRX-1 is a better option, even when they added DMR to the WS-1080, as it is the path with future updates. The WS-1080/WS-1088 is pretty much at the end-of-life stage. At some point the non-NXDN changes to the TRX-1 will not be included on the WS-1080.
I was disappointed when Whistler did not fully pick up support of the PSR-800, but I understand that GRE went out of business, and it is not Whistler's product. They did not want to be responsible for support, although they did release a couple of critical bug fix firmware versions, and still host the Firmware/RRDB files on their servers. They could at some point say "Enough!", although the same RRDB files are downloaded by the various iScan and EZ Scan apps. That is one reason I find exploration of this scanner ecosystem interesting. Improvements were made over the years instead of a complete redesign for every new model.
The TRX series is likely the last Whistler scanners using the M16c hardware platform. A different processor family with be required after most of the flash is used up. They may go with the RX630, like Uniden. This would mean a different code base and possible changing of file formats.
73 Eric
What will it do for the PRO-107 and PSR-700?
The tool will update the PRO-107 and the PSR-700 to their latest "official" firmware update version (if your scanner is not already at the latest version). For the PRO-107 that would be RU1.7 released on June 27, 2012 and for the PSR-700 that would be U1.7 dated January 9, 2012. If you have the appropriate iScan (Radio Shack PRO-107) or EZScan (GRE PSR-700) PC application software on your computer, you should be able to accomplish the same firmware update by using that program.
As has already been posted the PRO-107 and PSR-700 hardware is different from the PRO-18, PRO-668 and PSR-800, so the latest WS1080 CPU and DSP firmware will not run on those 2 models.
I need 3.8 Firmware,
anyone can help ?
