DMR interliving and deinterliving
DiggerPopPC
Hello! Need some help! I have 6 voice DMR RAW package:
1st pack
5a5a5a5a015f00004100050101000000111177771111000040128e0e2a15dd1446ded50b48af8775fd55f77d765f2b56db2631d5ef421f83249b00cb2a1501000200000033340500
2nd pack
5a5a5a5a025f000041000501010000001111888811110000407147734644d7f99088ef1dc58031c5203430501d59c1ee0ceb78751c324a7720ff0030464401000200000033340500
3rd pack
5a5a5a5a035f000041000501010000001111999911110000402b51b3fc8fcd13c75886291cd2b13c507010a44b57743e1ea10294aad2465b353600a2fc8f01000200000033340500
4st pack
5a5a5a5a045f000041000501010000001111aaaa11110000407e6853b919a7cc785306de673571710070a43049e7e302d193816759895e0964640006b91901000200000033340500
5st pack
5a5a5a5a055f000041000501010000001111bbbb111100004079affc634d7f792d9ba20d7e8871d74054f05070306f9688e1f5187d11c4f1b1ba00ca634d01000200000033340500
6st pack
5a5a5a5a065f000041000501010000001111cccc111100004062bdeac567c3e2326209c7d6d8916c5910a6a02c5ef346230ff7fae4eb13d77224006bc56701000200000033340500
and LC package:
5a5a5a5aff5e0000410005010100000011111111111100004090d100c844ac00081fe018c07c6d0457ff5dd7def52d30500380120010010c918000fbc84401000200000033340500
I know payload (33 bytes, for example for first package its 8e0e2a15dd1446ded50b48af8775fd55f77d765f2b56db2631d5ef421f83249b00). but I dont understand how I should make deinterleaver each package or all packages in one. I understand that system uses BPTC(196, 96) Encoder. Please explain me how I should take part of data and make real data. I saw the table of interleaver, but cant make from this data superframe. Please explain algorithm of this bit swapping.
boatbod
Talbot Co, MD
You could peruse the op25 sources, particularly dmr_cai and dmt_slot found in ~/op25/op25/gr-op25_repeater/lib
DiggerPopPC
Thanks for your answer. I found the decode function. I use it. But this function decode data information/ And I didnt found function which decoding voice data or I mistake?
Genguser
Those bytes are not in correct order. that site protocol using some different pattern. For reading what info are in burst you can use OK-DMR libs from Github link. there is support for decoding Hytera ip site. Here is what u have in LC burst. No more useful info you can get.
[BsSourcedData] [DataTypes.VoiceLCHeader] [CC: 1] [TS: 1]
[FLCOs.GroupVoiceChannelUser] [FeatureSetIDs.MotorolaLtd] [SOURCE: 365201] [GROUP: 1] [PRIVACY]
Voice is probably encrypted. That ok-dmrlib cannot play audio from frames.
boatbod
Talbot Co, MD
Regular DMR voice frames are decoded down in rx_sync.cc. bptc19696 is not used by op25 for voice.
DiggerPopPC
Thanks for your explain. And sorry for my mistake. I'm a little confused with data types. Now I understand that I use a different encoding. But the interleaving issue remains relevant. As I understand it, from each packet after decoding and bit swapping I should get three packets of 72 bits. For decoding I should use Golay's algorithm. Now I'm trying to figure out how it all works.
Genguser
From each packet you get 264 bits which is exactly one frame (burst). for de/interleave - in case bptc19696 is used , then you take 98 bits from left and 98bits from right. so it looks more like this 98bits/center_bits/98 bits. In more detail it is described in ETSI docs, where you can see it all how it works. ETSI from TS 102 361-1 to TS 102 361-4.
DiggerPopPC
You are right, but its work with data burst. Voice bursts is decode another way. You take 108bit from left - 48 bit its synch - 108 bit from right. This data you should decode. And bptc19696 is not used by op25 for voice.
DiggerPopPC
Thanks for your answers. I find information about good analyzer DMR. That is https://github.com/laforge/DMRshark. But now this project is empty. I found another GitHub - nonoo/dmrshark: dmrshark analyses the traffic, and adds extra features to a Hytera IPSC network. but its deamon and have another functions. Did you know some projects such https://github.com/laforge/DMRshark? Or maybe you know site with this projects?
boatbod
Talbot Co, MD
Sorry, I've got practically no receivable DMR in my local area so I don't spend a lot of time playing with it.
lwvmobile
DSD-FME
Lafayette County, FL
Alright, I'll bite on this.
What is the source of this payload information? Main reason I ask, is that none of those payloads have a DMR frame sync pattern in them. Also, the payloads you present seem to be (with an extra hex character on the end) two slots worth of BS, if you include the CACH information.
For example, ok-dmrlib asked me to implement a format like this for hex payloads. Here is a snort snippet of BS with IDLE in slot 2, and slot 1 with VLC, and the first voice superframe. The first hex value before the space indicates the slot of activity, the 98 indicates CACH, and the 6 hex values indicate the 3-byte CACH Payload. The longer sequence below those are the burst type '09' is IDLE, and then has a 33-byte payload.
Code:
2 98 888A22 //CACH
2 09 53C25EABA8671DC7383BD9360E4DFF57D75DF5D21FF6E465171B48CA6D4FC610B4 //Payload
1 98 008220
1 01 04F04242052434687A300B280C7DFF57D75DF5D504CC037A166617E406C0118015
2 98 880CD3
1 98 41DE52
2 98 889E7A
1 98 40D6A5
1 10 998C48E12777C57D8DBDA61A626755FD7DF75F757B15104FBD41545227BED3CCE7
2 98 880CD3
1 98 41DE52
1 10 F177B7160DEE7A06AF1019A716C320941000926CE4E2E2624498A33ABE41E8AE72
2 98 889E7A
1 98 40D6A5
1 10 0EAAA5D9F2310C2B78EDCACDE913600034105C3317C03B5D998C48E12777C57D8D
2 98 880CD3
1 98 41DE52
1 10 BDA61A62657B15104FBD4154522360090AA47C37BED3CCE7F177B7160DEE7A06AF
2 98 889E7A
1 98 40D6A5
1 10 1019A716CCE4E2E262558EA01E5349935A671B06BEA16AF6288AA3F97C6444A634
2 98 880CD3
1 98 41DE52
1 10 5B11B0FB610DD571E088AA0AC5A3000000000550414F1010FED43F0248EC16D8DE
If I take that sample, and compress it to just the useful bytes of payload, stripping the slot values and burst type values, you get something like this:
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
If I were to take that above, and dump it into a simple hex to dibit conversion tool that I literally just wrote up, you might get something like this:
Code:
----------------Hex to Dibit Tool----------------
 Include any leading zeroes in Input Message!
 Enter Input Message (Hex Octets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
 Len: 576; DLen: 2304;
  In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
 Out: 2,0,2,0,2,0,2,2,0,2,0,2,1,1,0,3,3,0,0,2,1,1,3,2,2,2,2,3,2,2,2,0,1,2,1,3,0,1,3,1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1,3,0,1,2,3,1,0,2,0,3,0,2,2,1,2,3,1,1,0,3,3,3,0,1,2,0,1,0,0,2,3,1,0,0,0,0,0,2,0,0,2,0,2,0,0,0,0,1,0,3,3,0,0,1,0,0,2,1,0,0,2,0,0,1,1,0,2,1,0,0,3,1,0,1,2,2,0,1,3,2,2,0,3,0,0,0,0,2,3,0,2,2,0,0,0,3,0,1,3,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,1,1,0,0,1,0,3,0,3,0,0,0,0,3,1,3,2,2,0,1,1,2,1,2,1,2,0,1,1,3,3,2,1,0,0,0,1,2,3,0,0,0,0,1,0,1,2,0,0,0,0,1,1,1,2,0,2,0,0,0,3,0,3,1,0,3,1,1,0,3,3,0,0,2,1,1,3,2,2,2,2,3,2,2,2,0,1,2,1,3,0,1,3,1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1,3,0,1,2,3,1,0,2,0,3,0,2,2,1,2,3,1,1,0,3,3,3,0,1,2,0,1,0,0,2,3,1,0,1,0,0,1,3,1,3,2,1,1,0,2,0,0,1,0,3,3,0,0,1,0,0,2,1,0,0,2,0,0,1,1,0,2,1,0,0,3,1,0,1,2,2,0,1,3,2,2,0,3,0,0,0,0,2,3,0,2,2,0,0,0,3,0,1,3,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,1,1,0,0,1,0,3,0,3,0,0,0,0,3,1,3,2,2,0,1,1,2,1,2,1,2,0,1,1,3,3,2,1,0,0,0,1,2,3,0,0,0,0,1,0,1,2,0,0,0,0,1,1,1,2,0,2,0,2,1,3,2,1,3,2,2,1,1,0,3,3,0,0,2,1,1,3,2,2,2,2,3,2,2,2,0,1,2,1,3,0,1,3,1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1,3,0,1,2,3,1,0,2,0,3,0,2,2,1,2,3,1,1,0,3,3,3,0,1,2,0,1,0,0,2,3,1,0,1,0,0,0,3,1,1,2,2,2,1,1,2,1,2,1,2,0,3,0,1,0,2,0,3,2,0,1,0,2,1,3,1,3,1,3,3,0,1,1,1,3,3,1,2,0,3,1,2,3,3,1,2,2,1,2,0,1,2,2,1,2,0,2,1,2,1,3,1,1,1,1,3,3,3,1,1,3,3,1,3,3,1,3,1,1,3,3,1,3,1,1,1,3,2,3,0,1,1,1,0,1,0,0,1,0,3,3,2,3,3,1,1,0,0,1,1,1,1,0,1,1,0,2,0,2,1,3,2,3,3,2,3,1,0,3,3,0,3,0,3,2,1,3,2,0,2,0,0,0,3,0,3,1,0,3,1,1,0,3,3,0,0,2,1,1,3,2,2,2,2,3,2,2,2,0,1,2,1,3,0,1,3,1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1,3,0,1,2,3,1,0,2,0,3,0,2,2,1,2,3,1,1,0,3,3,3,0,1,2,0,1,0,0,2,3,1,0,1,0,0,1,3,1,3,2,1,1,0,2,3,3,0,1,1,3,1,3,2,3,1,3,0,1,1,2,0,0,3,1,3,2,3,2,1,3,2,2,0,0,1,2,2,2,3,3,0,1,0,0,0,1,2,1,2,2,1,3,0,1,1,2,3,0,0,3,0,2,0,0,2,1,1,0,0,1,0,0,0,0,0,0,2,1,0,2,1,2,3,0,3,2,1,0,3,2,0,2,3,2,0,2,1,2,0,2,1,0,1,0,2,1,2,0,2,2,0,3,0,3,2,2,2,3,3,2,1,0,0,1,3,2,2,0,2,2,3,2,1,3,0,2,2,0,2,0,2,1,3,2,1,3,2,2,1,1,0,3,3,0,0,2,1,1,3,2,2,2,2,3,2,2,2,0,1,2,1,3,0,1,3,1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1,3,0,1,2,3,1,0,2,0,3,0,2,2,1,2,3,1,1,0,3,3,3,0,1,2,0,1,0,0,2,3,1,0,1,0,0,0,3,1,1,2,2,2,1,1,0,0,3,2,2,2,2,2,2,2,1,1,3,1,2,1,3,3,0,2,0,3,0,1,0,0,3,0,0,2,2,3,1,3,2,0,3,2,3,1,3,0,2,2,3,0,3,1,3,2,2,1,0,1,0,3,1,2,0,0,0,0,0,0,0,3,1,0,0,1,0,0,1,1,3,0,0,3,0,3,0,1,1,3,3,0,0,0,0,3,2,3,1,1,3,1,2,1,2,1,2,0,3,0,1,0,2,0,3,2,0,1,0,2,1,3,1,3,1,3,3,0,1,1,1,3,3,1,2,0,3,1,2,0,2,0,0,0,3,0,3,1,0,3,1,1,0,3,3,0,0,2,1,1,3,2,2,2,2,3,2,2,2,0,1,2,1,3,0,1,3,1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1,3,0,1,2,3,1,0,2,0,3,0,2,2,1,2,3,1,1,0,3,3,3,0,1,2,0,1,0,0,2,3,1,0,1,0,0,1,3,1,3,2,1,1,0,2,2,3,3,1,2,2,1,2,0,1,2,2,1,2,0,2,1,2,1,1,1,3,2,3,0,1,1,1,0,1,0,0,1,0,3,3,2,3,3,1,1,0,0,1,1,1,1,0,1,1,0,2,0,2,0,3,1,2,0,0,0,0,2,1,0,0,2,2,2,2,1,0,1,3,3,0,0,3,1,3,2,3,3,2,3,1,0,3,3,0,3,0,3,2,1,3,3,3,0,1,1,3,1,3,2,3,1,3,0,1,1,2,0,0,3,1,3,2,3,2,1,3,2,2,0,0,1,2,2,2,3,3,2,0,2,0,2,1,3,2,1,3,2,2,1,1,0,3,3,0,0,2,1,1,3,2,2,2,2,3,2,2,2,0,1,2,1,3,0,1,3,1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1,3,0,1,2,3,1,0,2,0,3,0,2,2,1,2,3,1,1,0,3,3,3,0,1,2,0,1,0,0,2,3,1,0,1,0,0,0,3,1,1,2,2,2,1,1,0,1,0,0,0,1,2,1,2,2,1,3,0,1,1,2,3,0,3,0,3,2,1,0,3,2,0,2,3,2,0,2,1,2,0,2,1,1,1,1,2,0,3,2,2,2,0,0,0,1,3,2,1,1,0,3,1,0,2,1,2,1,0,3,1,1,2,2,1,2,1,3,0,1,2,3,0,0,1,2,2,3,3,2,2,2,0,1,1,2,2,2,3,3,1,2,0,2,2,0,2,0,2,2,2,2,0,3,3,3,2,1,1,3,3,0,1,2,1,0,1,0,1,0,2,2,1,2,0,3,1,0,2,0,2,0,0,0,3,0,3,1,0,3,1,1,0,3,3,0,0,2,1,1,3,2,2,2,2,3,2,2,2,0,1,2,1,3,0,1,3,1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1,3,0,1,2,3,1,0,2,0,3,0,2,2,1,2,3,1,1,0,3,3,3,0,1,2,0,1,0,0,2,3,1,0,1,0,0,1,3,1,3,2,1,1,0,2,1,1,2,3,0,1,0,1,2,3,0,0,3,3,2,3,1,2,0,1,0,0,3,1,3,1,1,1,1,3,0,1,3,2,0,0,2,0,2,0,2,2,2,2,0,0,2,2,3,0,1,1,2,2,0,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,0,0,1,0,0,1,1,0,3,3,0,1,0,0,0,1,0,0,3,3,3,2,3,1,1,0,0,3,3,3,0,0,0,2,1,0,2,0,3,2,3,0,0,1,1,2,3,1,2,0,3,1,3,2,
 Written to file: dibits.bin
 Enter any value to Exit: 1
And If I were to in turn run that dibits.bin file into dsd-fme, I would get:
Code:
Build Version: AW 2025-92-g8bfdeee
MBElib Version: 1.3.4
CODEC2 Support Enabled
Logging Frame Payload to console
Decoding DMR BS/MS Simplex
Audio In Device: dibits.bin
21:33:07 Sync: +DMR   slot1  [slot2] | CACH/Burst FEC ERR
21:33:07 Sync: +DMR  [slot1]  slot2  | Color Code=03 | VLC
 SLOT 1 TGT=100 SRC=4112 FLCO=0x00 FID=0x68 SVC=0x40 Encrypted Hytera Group Call
 DMR PDU Payload [00][68][40][00][00][64][00][10][10][C6][97][A7]
 SLCO CRC ERR
21:33:07 Sync: +DMR   slot1  [slot2] | Color Code=03 | IDLE
21:33:07 Sync: +DMR  [SLOT1]  slot2  | Color Code=03 | VC1*
 AMBE F60FA79182EE80 err = [0] [0]
 AMBE E41DB58390FC80 err = [0] [0]
 AMBE C03991A7B4D880 err = [0] [0]
 Activity Update TS1: Group Voice; Hash: 59; TS2: Idle; Hash: 0;
 SLCO Completed Block [18][03][B0][07][30]
21:33:07 Sync: +DMR  [SLOT1]  slot2  | Color Code=03 | VC2
 AMBE 8871D9EFFC9080 err = [0] [0]
 AMBE 18E1497F6C0000 err = [0] [0]
 AMBE 39C0685E4D2100 err = [0] [0]
21:33:07 Sync: +DMR  [SLOT1]  slot2  | Color Code=03 | VC3
 AMBE 7B822A1C0F6300 err = [0] [0]
 AMBE FF06AE988BE780 err = [0] [0]
21:33:07 Sync: +DMR  [SLOT1]  slot2  | Color Code=03 | VC4
21:33:07 Sync: +DMR  [SLOT1]  slot2  | Color Code=03 | VC5
 AMBE 3939E9DF854900 err = [0] [0]
 AMBE 7B45DB1C0F0100 err = [0] [0]
21:33:07 Sync: +DMR  [SLOT1]  slot2  | Color Code=03 | VC6
 AMBE 4B111B15F6BE00 err = [0] [0]
 AMBE F6859D20022D00 err = [0] [0]
 AMBE E47B0C23581500 err = [0] [0]
 SB: 00000000000 - 000;
All this is to say, that unless you have a specific application that puts that format and only that format out, then its kind of a long way around to get to something that can be accomplished much easier with pretty much any DMR capable decoding software.
DiggerPopPC
Гаразд, я кусаю це.
Яке джерело цієї інформації про корисне навантаження? Основна причина, чому я запитую, полягає в тому, що жодна з цих корисних навантажень не має шаблону кадрової синхронізації DMR. Крім того, корисне навантаження, яке ви надаєте, здається (з додатковим шістнадцятковим символом у кінці) становить два слоти BS, якщо ви включите інформацію CACH.
Наприклад, ok-dmrlib попросив мене реалізувати такий формат для шістнадцяткових корисних даних. Ось фрагмент snort BS з IDLE у слоті 2 і слоті 1 з VLC, а також перший голосовий суперкадр. Перше шістнадцяткове значення перед пробілом вказує на слот активності, 98 вказує на CACH, а 6 шістнадцяткових значень вказують на 3-байтове корисне навантаження CACH. Довша послідовність під цими типом пакету '09' є IDLE, а потім має 33-байтове корисне навантаження.
[КОД]
2 98 888A22 //CACH
2 09 53C25EABA8671DC7383BD9360E4DFF57D75DF5D21FF6E465171B48CA6D4FC610B4 //Корисне навантаження
1 98 008220
2 98 880CD3
1 98 41DE52
2 98 889E7A
1 98 40D6A5
2 98 880CD3
1 98 41DE52
2 98 889E7A
1 98 40D6A5
2 98 880CD3
1 98 41DE52
2 98 889E7A
1 98 40D6A5
2 98 880CD3
1 98 41DE52
1 10 5B11B0FB610DD571E088AA0AC5A3000000000550414F1010FED43F0248EC16D8DE[/CODE]
Якщо я візьму цей зразок і стисну його лише до корисних байтів корисного навантаження, видаливши значення слотів і значення типу пакету, ви отримаєте щось на зразок цього:
Якщо я візьму це вище і перенесу це в простий інструмент перетворення hex to dibit, який я буквально щойно написав, ви могли б отримати щось на зразок цього:
[КОД]----------------Інструмент Hex to Dibit----------------
Додайте будь-які початкові нулі у вхідному повідомленні!
Введіть вхідне повідомлення (шістнадцяткові октети):
Довжина: 576; DLen: 2304;
в:
Вихід: 2,0,2,0,2,0,2,2,0,2,0,2,1,1,0,3,3,0,0,2,1,1,3,2,2,2,2,3,2,2,2,0,1,2,1,3,0,1,3,1,3,0,1,3,0,3,2 ,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,0,2,0,1 ,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1,3,0,1,2,3,1,0,2,0,3,0,2,2,1,2,3,1,1,0,3,3,3,0,1,2,0,1,0,0, 2,3,1,0,0,0,0,0,2,0,0,2,0,2,0,0,0,0,1,0,3,3,0,0,1,0,0,2,1,0,0,2,0,0,1,1,0,2,1,0,0,3,1,0,1,2,2, 0,1,3,2,2,0,3,0,0,0,0,2,3,0,2,2,0,0,0,3,0,1,3,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1 ,1,1,0,0,1,0,3,0,3,0,0,0,0,3,1,3,2,2,0,1,1,2,1,2,1,2,0,1,1,3,3,2,1,0,0,0,1,2,3,0,0,0,0,1,0,1,2 ,0,0,0,0,1,1,1,2,0,2,0,0,0,3,0,3,1,0,3,1,1,0,3,3,0,0,2,1,1,3,2,2,2,2,3,2,2,2,0,1,2,1,3,0,1,3, 1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3, 1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1,3,0,1,2,3,1,0,2,0,3,0,2,2,1,2,3,1,1,0,3,3,3 ,0,1,2,0,1,0,0,2,3,1,0,1,0,0,1,3,1,3,2,1,1,0,2,0,0,1,0,3,3,0,0,1,0,0,2,1,0,0,2,0,0,1,1,0,2,1,0 ,0,3,1,0,1,2,2,0,1,3,2,2,0,3,0,0,0,0,2,3,0,2,2,0,0,0,3,0,1,3,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1, 3,1,3,3,1,1,3,1,1,1,0,0,1,0,3,0,3,0,0,0,0,3,1,3,2,2,0,1,1,2,1,2,1,2,0,1,1,3,3,2,1,0,0,0,1,2,3, 0,0,0,0,1,0,1,2,0,0,0,0,1,1,1,2,0,2,0,2,1,3,2,1,3,2,2,1,1,0,3,3,0,0,2,1,1,3,2,2,2,2,3,2,2,2,0 ,1,2,1,3,0,1,3,1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3,1,1,1,3,3,1,1 ,3,1,1,3,1,3,3,1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1,3,0,1,2,3,1,0,2,0,3,0,2,2,1,2 ,3,1,1,0,3,3,3,0,1,2,0,1,0,0,2,3,1,0,1,0,0,0,3,1,1,2,2,2,1,1,2,1,2,1,2,0,3,0,1,0,2,0,3,2,0,1,0 ,2,1,3,1,3,1,3,3,0,1,1,1,3,3,1,2,0,3,1,2,3,3,1,2,2,1,2,0,1,2,2,1,2,0,2,1,2,1,3,1,1,1,1,3,3,3, 1,1,3,3,1,3,3,1,3,1,1,3,3,1,3,1,1,1,3,2,3,0,1,1,1,0,1,0,0,1,0,3,3,2,3,3,1,1,0,0,1,1,1,1,0,1,1, 0,2,0,2,1,3,2,3,3,2,3,1,0,3,3,0,3,0,3,2,1,3,2,0,2,0,0,0,3,0,3,1,0,3,1,1,0,3,3,0,0,2,1,1,3,2,2 ,2,2,3,2,2,2,0,1,2,1,3,0,1,3,1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3 ,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1,3,0,1,2,3,1,0, 2,0,3,0,2,2,1,2,3,1,1,0,3,3,3,0,1,2,0,1,0,0,2,3,1,0,1,0,0,1,3,1,3,2,1,1,0,2,3,3,0,1,1,3,1,3,2, 3,1,3,0,1,1,2,0,0,3,1,3,2,3,2,1,3,2,2,0,0,1,2,2,2,3,3,0,1,0,0,0,1,2,1,2,2,1,3,0,1,1,2,3,0,0,3 ,0,2,0,0,2,1,1,0,0,1,0,0,0,0,0,0,2,1,0,2,1,2,3,0,3,2,1,0,3,2,0,2,3,2,0,2,1,2,0,2,1,0,1,0,2,1,2 ,0,2,2,0,3,0,3,2,2,2,3,3,2,1,0,0,1,3,2,2,0,2,2,3,2,1,3,0,2,2,0,2,0,2,1,3,2,1,3,2,2,1,1,0,3,3, 0,0,2,1,1,3,2,2,2,2,3,2,2,2,0,1,2,1,3,0,1,3,1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2, 1,0,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1 ,3,0,1,2,3,1,0,2,0,3,0,2,2,1,2,3,1,1,0,3,3,3,0,1,2,0,1,0,0,2,3,1,0,1,0,0,0,3,1,1,2,2,2,1,1,0,0 ,3,2,2,2,2,2,2,2,1,1,3,1,2,1,3,3,0,2,0,3,0,1,0,0,3,0,0,2,2,3,1,3,2,0,3,2,3,1,3,0,2,2,3,0,3,1, 3,2,2,1,0,1,0,3,1,2,0,0,0,0,0,0,0,3,1,0,0,1,0,0,1,1,3,0,0,3,0,3,0,1,1,3,3,0,0,0,0,3,2,3,1,1,3, 1,2,1,2,1,2,0,3,0,1,0,2,0,3,2,0,1,0,2,1,3,1,3,1,3,3,0,1,1,1,3,3,1,2,0,3,1,2,0,2,0,0,0,3,0,3,1, 0,3,1,1,0,3,3,0,0,2,1,1,3,2,2,2,2,3,2,2,2,0,1,2,1,3,0,1,3,1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1, 1,0,1,1,3,0,1,2,3,1,0,2,0,3,0,2,2,1,2,3,1,1,0,3,3,3,0,1,2,0,1,0,0,2,3,1,0,1,0,0,1,3,1,3,2,1,1,0,2,2,3 ,3,1,2,2,1,2,0,1,2,2,1,2,0,2,1,2,1,1,1,3,2,3,0,1,1,1,0,1,0,0,1,0,3,3,2,3,3,1,1,0,0,1,1,1,1,0,1,1,0,2, 0,2,0,3,1,2,0,0,0,0,2,1,0,0,2,2,2,2,1,0,1,3,3,0,0,3,1,3,2,3,3,2,3,1,0,3,3,0,3,0,3,2,1,3,3,3,0,1,1,3,1 ,3,2,3,1,3,0,1,1,2,0,0,3,1,3,2,3,2,1,3,2,2,0,0,1,2,2,2,3,3,2,0,2,0,2,1,3,2,1,3,2,2,1,1,0,3,3,0,0,2,1, 1,3,2,2,2,2,3,2,2,2,0,1,2,1,3,0,1,3,1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3 ,1,1,1,3,3,1,1,3,1,1,3,1,3,3,1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1,3,0,1,2,3,1,0,2,0,3,0, 2,2,1,2,3,1,1,0,3,3,3,0,1,2,0,1,0,0,2,3,1,0,1,0,0,0,3,1,1,2,2,2,1,1,0,1,0,0,0,1,2,1,2,2,1,3,0,1,1,2,3 ,0,3,0,3,2,1,0,3,2,0,2,3,2,0,2,1,2,0,2,1,1,1,1,2,0,3,2,2,2,0,0,0,1,3,2,1,1,0,3,1,0,2,1,2,1,0,3,1,1,2 ,2,1,2,1,3,0,1,2,3,0,0,1,2,2,3,3,2,2,2,0,1,1,2,2,2,3,3,1,2,0,2,2,0,2,0,2,2,2,2,0,3,3,3,2,1,1,3,3,0,1, 2,1,0,1,0,1,0,2,2,1,2,0,3,1,0,2,0,2,0,0,0,3,0,3,1,0,3,1,1,0,3,3,0,0,2,1,1,3,2,2,2,2,3,2,2,2,0,1,2,1,3 ,0,1,3,1,3,0,1,3,0,3,2,0,0,3,2,3,3,1,2,1,0,3,1,2,0,0,3,2,1,0,3,1,3,3,3,3,1,1,1,3,3,1,1,3,1,1,3,1,3,3, 1,1,3,1,0,2,0,1,3,3,3,3,1,2,3,2,1,0,1,2,1,1,0,1,1,3,0,1,2,3,1,0,2,0,3,0,2,2,1,2,3,1,1,0,3,3,3,0,1,2,0 ,1,0,0,2,3,1,0,1,0,0,1,3,1,3,2,1,1,0,2,1,1,2,3,0,1,0,1,2,3,0,0,3,3,2,3,1,2,0,1,0,0,3,1,3,1,1,1,1,3,0, 1,3,2,0,0,2,0,2,0,2,2,2,2,0,0,2,2,3,0,1,1,2,2,0,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,0,0,1,0 ,0,1,1,0,3,3,0,1,0,0,0,1,0,0,3,3,3,2,3,1,1,0,0,3,3,3,0,0,0,2,1,0,2,0,3,2,3,0,0,1,1,2,3,1,2,0,3,1,3,2,0,1,0,0,3,1,3,1,1,1,1,3,0,1,3,2,0,0,2,0,2,0,2,2,2,2,0,0,2,2,3,0,1,1,2,2,0,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1, 1,1,1,0,0,1,0,0,1,1,0,3,3,0,1,0,0,0,1,0,0,3,3,3,2,3,1,1,0,0,3,3,3,0,0,0,2,1,0,2,0,3,2,3,0,0,1,1,2,3,1,2,0,3,1,3,2,0,1,0,0,3,1,3,1,1,1,1,3,0,1,3,2,0,0,2,0,2,0,2,2,2,2,0,0,2,2,3,0,1,1,2,2,0,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1, 1,1,1,0,0,1,0,0,1,1,0,3,3,0,1,0,0,0,1,0,0,3,3,3,2,3,1,1,0,0,3,3,3,0,0,0,2,1,0,2,0,3,2,3,0,0,1,1,2,3,1,2,0,3,1,3,2,
Записано у файл: dibits.bin
Введіть будь-яке значення для виходу: 1[/CODE]
І якби я, у свою чергу, запустив цей файл dibits.bin у dsd-fme, я б отримав:
[КОД]Версія збірки: AW 2025-92-g8bfdeee
Версія MBElib: 1.3.4
Підтримка CODEC2 увімкнена
Корисне навантаження фрейму журналу на консоль
Декодування DMR BS/MS Simplex
Аудіовхідний пристрій: dibits.bin
21:33:07 Синхронізація: +DMR slot1 [slot2] | ПОМИЛКА CACH/Burst FEC
21:33:07 Синхронізація: +DMR [slot1] slot2 | Код кольору=03 | VLC
СЛОТ 1 TGT=100 SRC=4112 FLCO=0x00 FID=0x68 SVC=0x40 Зашифрований груповий виклик Hytera
Корисне навантаження DMR PDU [00][68][40][00][00][64][00][10][10][C6][97][A7]
ПОМИЛКА CRC SLCO
21:33:07 Синхронізація: +DMR slot1 [slot2] | Код кольору=03 | ПРОСТОЮЧИЙ
21:33:07 Синхронізація: +DMR [SLOT1] slot2 | Код кольору=03 | VC1*
AMBE F60FA79182EE80 помилка = [0] [0]
AMBE E41DB58390FC80 помилка = [0] [0]
AMBE C03991A7B4D880 помилка = [0] [0]
Оновлення діяльності TS1: груповий голос; Хеш: 59; TS2: неактивний; Хеш: 0;
Завершений блок SLCO [18][03][B0][07][30]
21:33:07 Синхронізація: +DMR [SLOT1] slot2 | Код кольору=03 | VC2
AMBE 8871D9EFFC9080 помилка = [0] [0]
AMBE 18E1497F6C0000 помилка = [0] [0]
AMBE 39C0685E4D2100 помилка = [0] [0]
21:33:07 Синхронізація: +DMR [SLOT1] slot2 | Код кольору=03 | VC3
AMBE 7B822A1C0F6300 помилка = [0] [0]
AMBE FF06AE988BE780 помилка = [0] [0]
21:33:07 Синхронізація: +DMR [SLOT1] slot2 | Код кольору=03 | VC4
21:33:07 Синхронізація: +DMR [SLOT1] slot2 | Код кольору=03 | VC5
AMBE 3939E9DF854900 помилка = [0] [0]
AMBE 7B45DB1C0F0100 помилка = [0] [0]
21:33:07 Синхронізація: +DMR [SLOT1] slot2 | Код кольору=03 | VC6
AMBE 4B111B15F6BE00 помилка = [0] [0]
AMBE F6859D20022D00 помилка = [0] [0]
AMBE E47B0C23581500 помилка = [0] [0]
SB: 00000000000 - 000;[/CODE]
Все це означає, що якщо у вас немає конкретної програми, яка виводить цей формат і тільки цей формат, то буде довгий шлях, щоб дістатися до чогось, чого можна досягти набагато легше за допомогою будь-якого програмного забезпечення для декодування, що підтримує DMR.
Тhanks for your answer and your example In my example after deinterliveng and decoding voice frames I should to make one more action, make superframe and decrypt it. I know the key. But I try to understand the algorithm. What I must to do before decryption? Now I use Ok-dmrlib and dmr-utils3 library and find some functions which help me. I figured out how to get data from the LC header packet, and now I'm working on how to get a superframe from my packets. They have different conversion algorithms. I also want to understand how the superframe is decrypted and AMBE frames are obtained.
Genguser
Here is what i was able to reconstruct into dsd-fme. Audio is short obviously, but im pretty sure it is really encrypted by DMR PI line plus VLC.
Maybe lwvmobile can tell more from that log.
Code:
10:19:57 Sync: +DMR   slot1  [slot2] | CACH/Burst FEC ERR
10:19:57 Sync: +DMR  [slot1]  slot2  | Color Code=00 | IDLE
 SLCO CRC ERR
10:19:57 Sync: +DMR   slot1  [SLOT2] | Color Code=00 | VC1*
 AMBE 713DF12A000000 err = [0] [2]
 AMBE 849CCCFA004980 err = [3] [4]
 AMBE 839988B3E2F880 err = [0] [0]
10:19:57 Sync: +DMR   slot1  [SLOT2] | Color Code=01 | VC2
 AMBE 00E50B81A1E580 err = [0] [0]
 AMBE EA7229988B8A00 err = [0] [0]
 AMBE 111BABF5D59900 err = [0] [0]
 SLCO CRC ERR
10:19:57 Sync: +DMR   slot1  [SLOT2] | Color Code=01 | VC3
 AMBE 8F330F0DEDB280 err = [0] [0]
 AMBE A5D30ED255D300 err = [0] [0]
 AMBE 8B469DF7119600 err = [0] [0]
10:19:57 Sync: +DMR   slot1  [SLOT2] | Color Code=01 | VC4
 AMBE 17E700B39E3D00 err = [0] [0]
 AMBE 004C29E86F8F80 err = [0] [0]
 AMBE 2D5144D2AEC000 err = [0] [0]
10:19:57 Sync: +DMR   slot1  [SLOT2] | Color Code=01 | VC5
 AMBE F45A4FB12BFA80 err = [0] [0]
 AMBE B62D49F0174A00 err = [0] [0]
 AMBE 61AC84737F9600 err = [0] [0]
10:19:58 Sync: +DMR   slot1  [SLOT2] | Color Code=01 | VC6
 SLOT 2 TGT=1 SRC=365201 FLCO=0x00 FID=0x10 SVC=0x40 Group Encrypted Call
 DMR PDU Payload [00][10][40][00][00][01][05][92][91]
 AMBE F2ADAEFA6A2480 err = [0] [0]
 AMBE 79CBDDEED11A80 err = [0] [0]
 AMBE EE8818DF69E480 err = [0] [0]
 SB: 00001011001 - 059;
 Slot 2 DMR LE SB ALG ID: 0x21 KEY ID: 0x0B
 Slot 2 DMR PI C- ALG ID: 0x21 KEY ID: 0x0B MI: 0x00000000
 Slot 2 PI/LFSR and Late Entry MI Mismatch - 00000000 : 8DAC2684 (CRC OK)
10:19:58 Sync: +DMR  [slot1]  slot2  | Color Code=00 | IDLE
P.S. short link control lines was just added randomly. so slc lines has not correct values.
Also just little OT question to lwvmobile: does dsd-fme support replaying data without cach frames? i guess it doesn't. Im just asking because inside hytera ip multi-site connect is no cach or short link control informations (for at least what i know), so reconstructing those packets from .pcap into .bin isn't for one minute.
Edit: you were faster DiggerPopPC. So i dont know if that my answer is now still useful, but i cant delete it.
lwvmobile
DSD-FME
If you're going to try to reconstruct it up as a BS signal, then yeah, the CACH is necessary because it has the TACT bits in it, which also has the bit for the slot value (TDMA Channel) in it, otherwise on BS, it'll just throw a bunch of CACH/TACT errors because it wouldn't otherwise know hot to keep the payloads for each slot seperated. You could possibly have better luck doing it as a MS instead, you could just pass 000000 to CACH each time since its not on MS, just the timing is seperated the same. Also, you would need to just put in some zero payload fill for the 33-bytes of the empty TDMA slot for the same timing.
Just out of curiosity, how did you end up reconstructing those frames into payloads? I took a second look at it last night, but I couldn't get the payload to line up just right and just ended up with a bunch of errors after inserting a frame sync pattern and trying to seperate the payloads in-between the frame syncs.
Also, should note, that does appear to be DMRA RC4 going by embedded link control, the late entry that was pulled from the voiced frames with a good CRC and also the single burst on VC6.
Code:
DiggerPopPC
Code:
Thanks for your answer. But one more nubies question. What program did you use to get information. And how you take data to that program?
DiggerPopPC
I found dsd-fme project. It very interesting. I build it and install. But I dont understand how I should takes my packages to input this program. Please explain me how to convert my data and input it to program for result such yours.
