BCD325P2/BCD996P2: DMR OFT Question
tvengr
Well Known Member
Baltimore County, MD
How do you program DMR OFT where the database shows any TGID and the 2 talkgroups are selected by slot only? A TGID is needed to enter an alpha tag. Thanks!
sallen07
Rochester, NY
Is there a specific system in the database you are talking about?
tvengr
Well Known Member
FrequencyLicenseTypeToneAlpha TagDescriptionModeTag
151.4075WQPN446RMCC 10
TG *
SL 1
PC-911 OPS 1911 District Operations 1DMREmergency Ops
TG *
SL 2
PC-911 OPS 2911 District Operations 2DMREmergency Ops
Whiskey3JMC
Philly burbs 🇺🇸
Assuming either TGID can surface on either slot: You can still program each TGID and name it, just keep "set TDMA slot" set to "Both". If neither TGID is known then turn on ID Search to get them
sallen07
Rochester, NY
If you are required to have a TGID, just create a dummy one with any name and value you want, then turn on "ID search" on the system.
tvengr
Well Known Member
If you are not within range of the system, it's not possible to do an ID Search to find TGID's. Is it possible to program a DMR radio by frequency, color code, and slot only? I don't know.
sallen07
Rochester, NY
I don't understand the first sentence. If you are not in range of the system, then what's the point? What difference does it make how something you cannot monitor is programmed? If you are trying to program this for someone else, then they will have to watch for the TGIDs if they care and report back to you. If they just want to listen to the traffic, then ID Search will do just fine.
Most if not all Part 97 DMR radios have a promiscuous mode where you will hear ANY traffic on a frequency, with no regard to CC, slot, or TGID. You won't find that in commercial radios.
Whiskey3JMC
Philly burbs 🇺🇸
That will be challenging without the TG numbers, which the database does not list. :)
ID search makes it easy
You don't need to be within range to simply turn on ID search for the sole purpose of programming a system. Turn it on, program everything else in. Next time you're in range, gather the TGIDs and what slot they're on and modify your system accordingly
tvengr
Well Known Member
I am interested in being able to help someone else program the system. As I stated earlier, I don't know if it is possible to program a DMR talkgroup without a TGID into a commercial radio and select 2 talkgroups by slot only. Whether it is possible or not, it would be helpful to allow programming a wildcard TGID for talkgroups in a future firmware update for scanners. Thanks for everyone's help. I don't believe there is presently a way to select talkgroups by slot only.
Whiskey3JMC
Philly burbs 🇺🇸
Commercial radio, got it. Your "BCD996P2" prefix is a bit misleading...
tvengr
Well Known Member
The question is for scanners. I don't see any way to program alpha tags without a known TGID and select by slot only. I was just stating that I do not know if it is possible to program talkgroups into a DMR commercial radio without TGID's and select 2 talkgroups by slot only as shown in the database. I don't know if the person submitting to the database did an ID Search.
sallen07
Rochester, NY
I believe you are right ... no way to put in a separate alpha tag for each TS if you don't know the TGIDs. Pretty sure whoever did the submission didn't search for the TGIDs. I don't consider myself an expert on DMR but I know enough to be fairly certain there *has* to be a TGID in order to transmit.
tvengr
Well Known Member
I have been informed that Kenwood DMR radios have a Dual Slot Direct Mode where radios can be programmed using slots only. Scanners need to have a wildcard TGID available to be able to program in that mode.
hiegtx
Mentor
Dallas, TX
ID Search would get any TGID in use, and logging would help confirm the slot used for any TGID received. The most common "default" TGID I've seen is simply 1 Some of the smaller towns, using DMR for public safety, often use the same TGID, like 1, for both PD & FD, with slot specified for each department.
hiegtx
Mentor
Dallas, TX
That is true, but it will not help if the radio uses slots only (Dual Slot Direct Mode on Kenwood DMR radios).
I wonder if the scanner will simply treat that as TGID 1, even though no actual TGID was transmitted.
