DMR Programming Question - BCD 536
mondaro
Harrison, New Jersey
Hello,
I am trying to program a frequency in the 536 which is a simplex UHF frequency along with the
color code, I can not get it to work using one frequency DMR I can not get the radio to decode
not even keying up near the scanner with a DMR two way radio next to the scanner.
However if I program a DMR system using a repeater the radio decodes fine. Can anyone
give me any idea how I correct this mind-boggling situation.
Thank You.
Tony M.
New Jersey
kma371
Hello,
Thank You.
Tony M.
New Jersey
When you do one freq DMR, are you turning ID search "on""
racingfan360
The DMR Simplex decoding capabilities of the BCDx36HP are a bit rubbish.
For best results, try adding the frequency as a Quick Frequency Save. Make sure Modulation is set to FM (FUNC+CHAN/MOD until it cycles through to FM). Then go to MENU > Srch/CloCal Opt > Digital Wait time set to 400ms, Digital Threshold set to Manual, Digital Threshold Level set to 5.
Adding as a Quick Frequency Save also means you should see TGID and Unit ID (another rubbish aspect of the BCDx36HP is that you can't add a Conventional frequency with an alpha tag and still see this info).
