Or just record raw audio from the middle of any EP call. If the encryption is compatible with Motorola's DMR Enhanced Privacy, I'll pull out the key and the audio.
I generated an RC4 stream with a Tyt MD UV-390 PLUS (Motorola compatible) and took a superframe in the middle of the stream.
Since hacking is forbidden if you find the key, which I absolutely do not believe,
you should not give me the whole key but only 3 bytes, I will then give the other 2 bytes, which will prove that the transmission belongs to me and the key belongs to me.
Code:
Slot 1 DMR LE SB ALG ID: 0x21 KEY ID: 0x01
Slot 1 DMR PI C- ALG ID: 0x21 KEY ID: 0x01 MI: 0xB2FA85B2
13:12:04 Sync: +DMR MS/DM MODE/MONO | VC*
AMBE 8C2F87BE000080 err = [0] [0]
AMBE F6F1211C006100 err = [0] [0]
AMBE FB2FEE701AE000 err = [0] [0]
AMBE 45A9061E128B00 err = [0] [0]
AMBE 763CBA8C489500 err = [0] [0]
AMBE FE50A117551080 err = [0] [0]
AMBE 322016A96ACC00 err = [0] [0]
AMBE 474A3D72EBF500 err = [0] [0]
AMBE 889E7FAE82DB80 err = [0] [0]
AMBE 213C6302A59B00 err = [0] [0]
AMBE 32A0EEC9215100 err = [0] [0]
AMBE 8B82295C043E00 err = [0] [0]
AMBE 1FED707A69F080 err = [0] [0]
AMBE F512A7E719D100 err = [0] [0]
AMBE 0B9E90064FA100 err = [0] [0]
AMBE 52C830052CC280 err = [0] [0]
AMBE FAA31AF1363D80 err = [0] [0]
AMBE 80C36404241400 err = [0] [0]
SLOT 1 TGT=174 SRC=27541 FLCO=0x00 FID=0x10 SVC=0x40 Group Encrypted Call
No offence, but your deducing is essentially worthless - produce that raw audio sample and prove me right or wrong.
Even without talking about radio, all software that tries to decrypt something by testing the key, must have a stop test. If you don't have a silence frame, you don't know how to stop searching for the key, and you'd have to listen to the decryption of each key to verify if the sound you're hearing is from the human voice or not. And for that, the conversation needs to be long.
The AMBE vocoder produces data that is too random, you don't know what data to look for if you don't have a silence frame.
I guess you're going to answer me "well it doesn't work, it's normal I don't have an MD UV390 PLUS so I don't know how the vocoder is set, it doesn't work the same way as my own radios".
