DMR Silence Frame
Red_Ice
Does anyone know what FID the silence frame E6F1B76F921080 corresponds to in a DMR transmission, thanks.
Red_Ice
Thanks noamlivne, the frame you have given me (F801A99F8CE080) is from Motorola, the frame E6F1B76F921080 may be from Vertex, but I'm not sure about it, thanks for answering.
hrh17
Hmmm I haven't seen that one before either. Do you have any raw recordings?
Red_Ice
Sorry @hr17, I don't usually save the audios, I usually save the logs to study them later, here I show you the capture of the voice super frame.
[36m DMR PDU Payload [00][10][40][00][00][64][00][09][95][4F][BB][CE][0m
10:51:08 Sync: +DMR slot1 [slot2] | Color Code=05 | IDLE
[33m SLCO Activity Update TS1: 8 Hash: 3B TS2: 0 Hash: 00
SLCO Completed Block [18][03][B0][07][30][0m
10:51:08 Sync: +DMR [SLOT1] slot2 | Color Code=05 | VC1*
AMBE E701B69F93E080 err = [0] [0]
10:51:08 Sync: +DMR [SLOT1] slot2 | Color Code=05 | VC2
10:51:08 Sync: +DMR [SLOT1] slot2 | Color Code=05 | VC3
10:51:08 Sync: +DMR [SLOT1] slot2 | Color Code=05 | VC4
AMBE 8702A64FBBD380 err = [0] [0]
AMBE B33151A158D380 err = [0] [0]
AMBE 7433EEBE00F800 err = [0] [0]
10:51:08 Sync: +DMR [SLOT1] slot2 | Color Code=05 | VC5
AMBE 8710E319B3F200 err = [0] [0]
AMBE 97397F538DC780 err = [0] [0]
AMBE 6733B22299CD80 err = [0] [0]
10:51:08 Sync: +DMR [SLOT1] slot2 | Color Code=05 | VC6
[31m SLOT 1 FLCO FEC ERR [0m[31m (FEC ERR)[0m
[36m DMR PDU Payload [00][10][40][00][00][64][00][09][95][0m
[36m SB: 00000000000 - 000[0m
AMBE 6231CBFDB26080 err = [0] [0]
AMBE 97217709588480 err = [0] [0]
AMBE A7256093DCE780 err = [1] [0]
Red_Ice
Maybe it was my mistake, because when XORing E701B69F93E080 with E6F1B76F921080, it also returns 1F00
hrh17
Yes on Phase 2 only. Phase 1 uses another set of silent frames
MTL_Emergencies
Member++
Quebec, Canada
I did some research with OP25 on a Motorola P25 Phase I system and I found this code word 04 0c fd 7b fb 7d f2 7b 3d 9e 44 appearing at the start and end of every voice transmission.
boatbod
Talbot Co, MD
Are you saying it’s possible to deduct the key from the keystream?
xMBE encryption is based on XOR'ing the ciphertext with the key. If you know the ciphertext, know what to expect for the plaintext, and have received the MI you can theoretically compute the missing information which is the key.
EI9BAB
Nope. Every vendors is different
As mentioned above (and in a few other places) the Motorola Silence Frame is F8 01 A9 9F 8C E0 80
I believe that the Anytone Silence frame is 00 00 00 00 00 00 00 (or possibly 00 00 00 00 00 02 00)
Does anyone know what the Hytera silence frame looks like please?
(Or could someone provide me with a decent raw .WAV sample of an unencrypted Hytera transmission so I can work it out myself?)
EI9BAB
It does actually seem that the Hytera silence frame is the same as the Motorola one. (Many thanks to Noah for supplying me with a sample file to determine this.)
MTL_Emergencies
Member++
Quebec, Canada
Is there a reason why Motorola and other manufacturers add silence frames in the beginning of every transmission?
And also why isn't it the case with base radios (using TBROnet solutions i.e.)?
