DO NOT SCAN FULL DATABASE
LMHODNETT
HELENA, ALA.
I saw a few days ago someone had asked if you could avoid scanning the full database and now I cannot find it. I have my favorites setup but would like to avoid full database if possible. Any help?? Sorry for the post. I just found it and it works.
trentbob
W3BUX- Bucks County, PA
Push menu, choose set scan selection, select list to monitor, toggle full database off.
hiegtx
Mentor
Dallas, TX
BCD536 model. I found the post I was looking for and it worked. Thanks for you response.
Be sure and also correct your Profile in Sentinel. In Sentinel, where you specify which Favorites lists to be downloaded and/or monitored, there is a checkbox to set the main database to be monitored as well. Uncheck that box so that the scanner does not start scanning the database every time you load an update to one of your Favorites lists.
trentbob
Another way could be that when you hook up to Sentinel, first thing you do is transfer data from the radio to your profile so as to permanently save any changes you made on the radio manually through the menu.
