Does XTS-3000 encryption work in analog or just in digital mode
human8472
Looking at an XTS-3000 that supports two encryption modes ...
DES-XL
DES-OFB
Does the encryption work in analog mode or does it only function when operating in digital mode? Thank you.
DES-XL does analog.
DES-OFB is for digital modes.
Keep in mind you will need access to a key loader device to load DES-XL encryption keys into your radio.
V188
XL does work in wide band analog. Good luck making it work in narrow band analog, such as public service type frequencies. But then you'd need a KVL, and their code, and it still wouldn't work. Can't use it on ham channels either. It is good to experiment with electronics, it is the whole purpose of ham.
human8472
Is a KVL needed for DES-OFB encryption mode (i.e. Digital)? Can a key be entered through programming software (i.e. RSS) or via the keypad?
DES-XL does analog.
tsalmrsystemtech
You have to use a KVL to load the encryption key into the ENC board. No other way
jhal94
Pinellas County, Florida
You need a KVL for any encryption mode unless it is ADP on an Astro25 series radio. ADP is also digital only and very weak.
