Reconrider
Inside the Galaxy
I have 3 instances running from 1 directory. All using single dongles also.Are you running both instances in the same directory?
You gotta add -F# as an argument where # = a number between 1 and 99
No Problem, Glad I can help!Thanks, that will help me with following what's happening with all the new radios that are being deployed at the moment.
I think that is how data can be corrupted between systems, especially on initial startup, or when scoping out new systems.
I have a directory for each established system and test directories for new discoveries.
I have been running up to four instances in the same folder for years and have never had an issue. Each instance is named differently with the -F parameter.This is definitely true, unless one uses the particular switches required to run multiple versions from one directory. I've never done it myself.
DSD+ 2.176
In -r1 mode, multiple copies of DSD+ and FMPx can run in the same folder and share the
DSD+ data files. Each DSD+/FMPx pair can monitor different sites or systems.
Use the -F<num> file name modifier on the DSD+ command line for each additional copy of
DSD+ to avoid file naming conflicts.
