Does anyone know how to link DSD+ (Latest version: December 4, 2025) to SDRSharp? I tried TCP, that don't work, I want to go to the classic Input and Output over VB Cable but I can't seem to find the option to do that because its trying to force TCP. I don't need TCP because I just want to do this Local on my PC at home, and don't need any server or network software. Does anyone know how to switch to regular Input/Output?
You do not need anything to use tcp. No server or special software. Tcp would work on any pc not even connected to a router.
For best results decoding digital, its always best to use what's in DSDPlus (which includes 3 tuners) and skip the BS virtual cables and Sdr#.
If you still want to use DSDPlus with Sdr# via virtual cable, this is how it can be done on older sdr# 1742 with the DSD plugin.
Select the virtual cable in the plugins Audio device dropdown. Do not click Start DSD. Tune to a digital freq. Select Enable aux audio output in the plugin.
Open DSDPlus and select Passive Digital Monitor under Control tab.
Then select your input (virtual cable) in the Input tab.
You should see stuff scrolling on one of the screens that opened.
This method works only on conventional digital. It will not work on trunked systems.
