DSD Fastlane RTL-SDR TCP Protocol Error
m6sso
Hello all,
Cant seem to find out if anyone has had this error before but I am trying to use DSD+ 1R and FMP to control my RTL-SDR. The issue I have is every time I try to change frequency i get in the event log I get "TCP Protocol error / incompatible DSD+/FMPx versions" I have disabled my Firewall on my system to rule that out.
I am running FMP-VC.bat to load FMP and in DSD using the " use FMPx TCP linking"
I have attached a photo of the error.
dsd error.PNG.
Thanks in advance everyone
enosjones
Price, Utah
Try to see if u have the current versions of the fmp files , I ran into a similar issue ,I didn't have the right version of all the files to work with the current version of dsdplus, just make sure all files are updated
slicerwizard
Toronto, Ontario
FMP isn't compatible with DSD+ FL. Use FMP24. Use the FMP24-CC.bat file to run FMP24 and the 1R.bat file to run DSD+.
Using DSD+ with supported SDR devices
Single-dongle monitoring:
To use a single device, run the 1R.bat file to start DSD+,
then run the appropriate batch file for your device:
DVB-T dongle: FMP24-CC.bat
