MELERIX
- Joined
- Nov 19, 2018
- Messages
- 116
- Reaction score
- 62
nothing strange in the log related with RTL
but I think I'll need to make a video about the issue and sent it you in a private message xD
Code:
Build Version: AW 2025-216-gabf2859 (CYGWIN)
MBElib Version: 1.3.4
CODEC2 Support Enabled
Decoding P25 and DMR
Enabling NCurses Terminal.
RTL Input: Found 1 device(s):
0: RTLSDRBlog, Blog V4, SN: 00000001
Selected Device #0 with Serial Number: 00000001
Dev 0 Freq 868837500 Gain 20 PPM -4 BW 12 SQ 0 VOL 2
OSS Output /dev/dsp.
Using OSS Output with 8000k/2 channel configuration.
Audio In Device: rtl
Setting RTL PPM Error Set to -4
Setting RTL Bandwidth to 12000 Hz
Setting RTL RMS Squelch Level to 0
Found Rafael Micro R828D tuner
RTL-SDR Blog V4 Detected
Using RTLSDR Device Index: 0.
Tuner gain set to 19.70 dB.
Tuner error set to -4 ppm.
(Center Frequency: 869089500 Hz.)
Oversampling input by: 84x.
Oversampling output by: 1x.
Buffer size: 8.13ms
Exact sample rate is: 1008000.009613 Hz
Sampling at 1008000 S/s.
Output at 12000 Hz.
