DSD Plus Niagara County
Phoenix-23
Cheektowaga
Has anyone used DSD Plus fastlane on the Niagara county system and gotten any radio alias data
Yep. I haven't personally, but I can say for sure that somebody has.
BEE00.4F1 Niagara County NY 0 1424
As @mtindor said, I too haven't logged any, but someone has logged over 1400 RID aliases with none pending.
GTR8000
NY/NJ Database Guy
BEE00
Not unless the person(s) logging them send you their DSDPlus.radios file, nope.
ak716
'Merica
Yes, and yes. It's working great.
Are you referring to the RIDs in the 14XXXXXX range? I have yet to receive/decode a 1400XXXX ID (I only see about 10 that I've logged, ever, but the 149XXXXX range is all NYSP portables. 141XXXXX, I have a few, and those decoded as SP mobiles.
Looking at any 14XXXXXX RIDs, they are clearly LE, as they all have the last activity on either LE Primary, LE Data, or the US Marshal TG.
Phoenix-23
Cheektowaga
I actually have a ton of them was looking to confirm what have I am willing to share if anyone wants
ak716
'Merica
My Event Log shows 1378 MotoOTA; 1378 MotClr; 0 MotPat, but I manually figured out a bunch a while back before the OTA release, so.... I think that's me?
DaveNF2G
Latham, NY
The ones you added or edited yourself should be listed as a quantity of "user aliases" just before the MotOTA segment.
For example, the line on my screen for the Albany/Schenectady County (NY) system says:
8481 radio records saved; 8128 user aliases; 3236 MotOTA; 3236 MotClr; 0 MotPart
dave3825
Suffolk County NY
Manually figuring out radio id's (which is something many of us do) vs the "1738 MotoOTA" id's shown in DSDPlus are not the same. Those are the actual aliases programmed into the radios that are being decoded by a PC run by DSDPlus.
GTR8000
NY/NJ Database Guy
BEE00
The OTA aliases come from the system itself (Provisioning Manager), they are not "programmed into the radios".
Phoenix-23
Cheektowaga
You shouldn't be having any issues from there. I can receive it from York Region (north of Toronto) without issue. I'd double check your programming.
What are you using as a control channel I don't do any sdr stuff it's all new to me
lkas
Cheektowaga NY
I must be doing something wrong
i have a omni X antenna outside which picks them up. Also i recently added a uhf yagi which picks them up. The signal is fairly strong and i pick it up reliably with no issues.
