DSD+ Status
KG5CUO
Redfield, Ar
I am geting errors and no data here is what i am seeing.
ChillaGorella@PC101 ~
$ dsdplus -fr
DSDPlus Rev 1.051
Appending synthesized audio to file 'DSDPlus.wav'
audio input device #1 = 'Stereo Mix (Realtek High Defini'
audio input device #2 = 'Line 2 (Virtual Audio Cable)'
audio input device #3 = 'Line 1 (Virtual Audio Cable)'
audio output device #1 = 'Speakers (Realtek High Definiti'
audio output device #2 = 'AMD HDMI Output (AMD High Defin'
audio output device #3 = 'Line 2 (Virtual Audio Cable)'
audio output device #4 = 'Line 1 (Virtual Audio Cable)'
audio input device #1 (Stereo Mix (Realtek High Defini) initialized
audio output device #1 (Speakers (Realtek High Definiti) initialized
DMR/MotoTRBO decoding enabled
Mono audio decoding initiated; press Esc to exit...
Code:
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 CC=8  Voice Hdr
Sync: no sync
Sync:-DMR
-DMR  CACH ERR slot1         BS DATA  ERR3 CC=9  Unknown TypeB
Sync: no sync
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 CC=8  TLC
Sync: no sync
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 CC=0  Unknown TypeB
Sync: no sync
Sync:+DMR
+DMR                slot2    BS DATA  ERR3 CC=4  Voice Hdr
Sync: no sync
Sync:+DMR
+DMR                slot2    BS DATA  ERR3 CC=1  TLC
Sync: no sync
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 CC=10  MBC Header
Sync: no sync
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR2 CC=6  Rate 3/4 Data
Sync: no sync
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 CC=10  Data Header
Sync: no sync
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 CC=9  MBC Header
Sync:+DMR
+DMR                slot2    BS DATA  ERR2 CC=15  Rate 1/2 Data
Sync: no sync
Sync:+DMR
+DMR  CACH ERR slot1         BS DATA  ERR3 CC=10  Rate 3/4 Data
Sync:+DMR
+DMR                slot2    BS DATA  ERR3 CC=3  Data Header
Sync: no sync
Sync:+DMR
+DMR                slot2    BS DATA  ERR3 CC=8  MBC
Sync: no sync
Sync:-DMR
-DMR  CACH ERR slot1         BS DATA  ERR3 CC=9  Rate 1 Data
Sync: no sync
RonnieUSA
Rowan County,KY (Morehead)
Open your command prompt window and type or copy/paste the following:
DSDPlus -h > Help.txt
This will save the the screen output as a text file called "Help.txt".
You can use another file name if you don't like Help.txt.
Thank You very much, that did the trick, plus I got my logging back thanks the help file.
woodpecker
Thanks for the program but I find after the program has been running some time (few hours) it seems to stop syncing correctly, I just tuned to a strong DMR signal and it was totally garbled, restarted dsd+ and it decoded fine again, any idea what's causing this?
WayneH
Forums Veteran
Super Moderator
Your master site
I don't have this specific issue after running for hours but I've had it hang up multiple times and stop decoding. No response so I just close the DOS window. Then sometimes when hitting ESC it shows exiting... but never completely closes. Gotta close the DOS window again.
Memory handling issue??
WayneH
Forums Veteran
Super Moderator
Your master site
Why aren't you choosing the appropriate input source? Have you tried anything to troubleshoot it like adjust levels, decode a nice, strong signal, etc?
RonnieUSA
The only problems I have had were with some encrypted frequencies, that I wanted to see the user ID's, and after that I had no audio for anything .
All I had to to was restart DSD+.
Annunaki
Same here but on my system it seems to happen when moving the various DSD+ windows around but yeah I too am experiencing this sync issue even on strong signals.
Restarting DSD+ fixes it until it does the same again.
W4KRR
Coconut Creek
On the bottom of the DSD+ Event Log screen, the bottom of the window shows "NL:3 5 6 7" for example. What does this indicate? This is when decoding a NXEDGE48 system.
swm239
install error
Hello, I have put DSD + one one desktop and 1 laptop, installed and running right away.; Have a 2nd laptop and desktop and have tried several times to install and start. Each time I get a system error. program cant start because lame_enc.DLL is missing. try re installing. Have done this several times and even copied the dll file by itself, even getting questioned if I want to overwrite the current dll file. Still unable to get it stat. Anyone else seeing this or have any thoughts.? Thanks a lot
BM82557
Berkeley Co WV
See Audacity: How do I download and install the LAME MP3 encoder? , download and run Lame v3.99.3 for Windows.exe,
Forts
Ontario, Canada
What's Neighbor List mean?
Trunked system sites have neighbours which the subscribers can roam to if need be. Usually roaming occurs when the signal from the current site falls too low, so the radio will check it's neighbors to see who has the best signal strength. If the subscriber is allowed to roam it will switch to another site. If it isn't, then it may lose signal and fall off the network. Usually users are only allowed to roam between certain sites.. For example a taxi company in London doesn't need site access in Toronto, but it might in St Thomas.
joeuser
The Wretched
North Central Kansas
Thank you
sbarnes
Brisbane
Just want to say thank you to the developer for this great software works great!
With the LRPP does it read of the transmission data when its decoding the current signal or is separate signal?
Regards
Shane
woodpecker
I can't replicate it by moving the windows around, the original version had this same issue as well.
D
DaveNF2G
Guest
Could be a memory problem, especially if using DSDPlus with SDRSharp. After SDRSharp has been running for a while (especially after a lot of tuning around), it starts throwing protected memory errors.
KC1UA
This ain't gettin us noplace, we'll have to blast!
Marstons Mills, Cape Cod, Massachusetts
Hi,
Has anyone figured out how to turn on file logging when running DSDPlus from within SDR#. Thanks in advance.
Also, for a future version I think it would be nifty to be able to toggle logging on and off via a smart key. It appears audio logging can be toggled from there; I haven't tried that yet.
Thanks again, it's working superbly here on numerous setups.
