DSD+ Status
LesWurk
Land of RF
Great program, love it. Question how can one clear out gps points in LRRP? Is there a way to only show activity to the last xx minutes, say 15 minutes?
frazpo
SW Mo
Hi.
1.51 starts on Elementary OS /w wine. I don't know if it's decoding any data. I've to check it.
I connected cable to audio in and put my fingers on the plug. So you can see some signal in source audio window.
Update on this? I have Ubuntu loaded I may try it with.
WayneH
Forums Veteran
Super Moderator
Your master site
Fixes for IDAS issues require raw audio samples. To date, very few IDAS samples have been uploaded.
I can provide whatever you need. If you have any special requests then let me know. These are via DSD+:
Clean voice with no beacons. Valid free channels are 4, 10 & 20.
https://www.dropbox.com/s/kd0aahlwuslbzbx/IDAS_S15_CH06_Raw.7z?dl=0
Longer sample with beacons though the signal is a little rough. Free are 4, 13, 15, 16, 20 & 30.
https://www.dropbox.com/s/q2uqhq0g5sby9v4/IDAS_S04_CH18_Raw.7z?dl=0
DSDPlus
IDAS decoding has been upgraded, but the standards documents are not clear on the meaning of special ID 2043.
DSDPlus
You can edit the DSDPlus.LRRP file to remove unwanted entries. A third party could write a program to automate this.
WayneH
Forums Veteran
Super Moderator
Your master site
I don't recall seeing it so if it's at a lower level that's not shown I can't help you as I don't have any kind of raw data dumping software.
Totally unrelated feature requests:
-- The ability to disable voice decoding based on a TG (or a range via regex?) of a system. I get a lot of chatty spanish speaking people around me.
-- When decoding IDAS to send decoded audio to a specific audio channel rather than mono. I setup IDAS systems to scan in SDR# so this makes figuring out which TG goes with which voice.
-- Following the audio topic, the ability to outright mute decoded voice. Sometimes I just want to analyze without muting everything else.
Thanks!
ve2cq
Quebec Canada
Complete documentation and raw audio samples would have to be provided.
For raw audio samples, i'l try my best to provide some, as there is a local Fusion repeater that i doing a local net evey wednesday night.
jazzbassNick
San Gabriel CA
@DSDPlus Program unexepectedly quit. Here's the output:
Code:
Unrecoverable error encountered:
Write failure.
Address:41D1CA  File handle:492  Block:2B97D34
Block size:22  Bytes written:0
Filename: 'DSDPlus.event'
Please report this error to the program author.
jcardani
Orlando, FL
DVSI USB3000 vocoder support ?
While we are asking for feature enhancements, how about DSDPlus support the DVSI USB3000 P25 vocoder? Or allow a 3rd party programmer to interface? Eric was working with this USB device but not sure if the code is complete. One thing I remember is that the device performs interleaving so that would need to be turned off in DSDPlus when interfacing the USB-3000.
thanks,
DSDPlus
Thanks, monitoring the Nexedge trunk in my area is a pain when having to hear scrambled audio. Muting it would be the best. :)
Would you please upload some raw audio samples? They will be needed to test muting.
Saint
Fort Erie Ontario Canada
Future enhancements
Is there any way to get DSD+ to pass over some talkgroups that I have found in a system, if you could get DSD+ to pass over them then it would be a lot easier finding unknown talkgroups, maybe have a plain text file with the talkgroups you want to pass over and DSD+ read the file and Passover any talkgroups in the file or something along those lines. don't know if it's even feasible.
Steve
joeuser
The Wretched
North Central Kansas
Steve
Wouldn't you just do that in Unitrunker? DSD+ just decodes what UT feeds it, right?
