DSD+
john56
Toledo, Ohio
Listening to a DMR System that Wood County Sheriff and Bowling Green Police switched to....now
on the Bowling Green Channel..just got a data burst..screen says all data...so I assume no voice was with it at that time...
John
john56
Toledo, Ohio
OK...still getting motorboating, no voice..however the DSD Event log is showing talkgroup numbers...did not get that before
John
j0atm0n
Wapakoneta Ohio
are you seeing cache errors etc in the dsd interface ?
you may have to adjust the levels and reduce your bandwidth window lower
j0atm0n
Wapakoneta Ohio
decoding seems to work alot better with lower sample rates ,
i keep mine around .900001 MSPS - .25 on weaker distant signals .
look at your wave form window of dsdplus make sure its in a happy state of
mid levels no peaking - not to quiet - and right in the middle of the window
john56
Toledo, Ohio
I am seeing cache err in the scrolling....I adjusted my line in level down to 24 it was at 94...don't know
if that was the issue...will see
How do I adjust the bandwidth on SDR?
John
j0atm0n
Wapakoneta Ohio
gear symbol up top that opens the controller options ,
where you can adjust rf gain and agc ,
adjust the sample rate lower
older slower systems might not be able to process higher rates
in a efficient enough manner to decode the audio without errors
john56
Toledo, Ohio
IT is showing saved groups, etc in DSD Event Log, never got that far beore, but still no voice, just that data noise
John
j0atm0n
Wapakoneta Ohio
ok next few things :
on the sdr# plugin if you select "mute this frequency" it will kill the audio noise your hearing but will still pass audio to dsd+,
( it basically just sets sdr# to mute every time your on that selected freq )
& it will save that frequency info in a digital_frequencies.xml file for future muting,
next :
open up your volume mixer on windows and double check that dsd + volume level is turned up.
and also you can turn down the volume for the virtual audio
( just check and make sure it doesnt effect the levels that dsd+ is hearing )
j0atm0n
Wapakoneta Ohio
try .25 ( or your lowest sample rate )
also :
click on the dsd plugin configure option again up top there's a decoder option tab ,
check it over , I use the "auto detect" option .
j0atm0n
Wapakoneta Ohio
ok little hind sight here , since i know your using the plugin now ,
make sure that sdr# is set for audio output to your speakers and not to virtual audio
incase you might be double feeding same audio into dsdplus 2x
john56
Toledo, Ohio
Everything checks OK...while they were transmitting, I set the symbol rate down to .25 still no voice.
Audio level is up on DSD in volume mixer
John
