DSDplus/DMRdecode
G7VDI
Hi, I am wondering why my setups are not displaying information such as the talkgroup numbers whilst I am decoding local DMR systems?
A problem as I am wanting to program them into other equipment.
Setup is an AOR AR-DV1 (using the discriminator output; the DV1 now displays the colour code and timeslot following a recent firmware update but not as yet the talkgroup in use; AOR say this functionality may be added later).
Anyone got any suggestions? Signal is about 3 S points on the meter.
Regards, David
racingfan360
So what is DSD+ actually displaying?
Can you make a raw recording using DSD+ and post a link to the uploaded file for analysis?
(If I were to make a guess right now, I'd say your DV1 isn't actually outputting a discriminator signal)
G7VDI
Here's the output I get...
From the .event file:
2016/02/04 22:57:01 DSD+ 1.101pt [Public Release]
2016/02/04 22:57:01 D-STAR decoding enabled
2016/02/04 22:57:01 NXDN4800 decoding enabled
2016/02/04 22:57:01 NXDN9600 decoding enabled
2016/02/04 22:57:01 DMR/MotoTRBO decoding enabled
2016/02/04 22:57:01 P25 Phase 1 decoding enabled
2016/02/04 22:57:01 X2-TDMA decoding enabled
2016/02/04 22:57:01 ProVoice decoding enabled
2016/02/04 23:14:22 Emerg Enc Bcast OVCM Group call; TG=65485 RID=2929782 Slot=1
2016/02/04 23:15:35 Emerg Enc Bcast OVCM Group call; TG=65485 RID=2930630 Slot=1 7s
2016/02/04 23:16:04 Emerg Enc Bcast OVCM Group call; TG=65485 RID=2929782 Slot=1 20s
2016/02/04 23:17:13 Emerg Enc Bcast OVCM Group call; TG=65485 RID=2930630 Slot=1 1s
From the SRT file:
00:00:00,000 --> 00:00:01,000
2016/02/17 16:41:49
-DMR Slot 2
2
00:00:01,000 --> 00:00:02,000
2016/02/17 16:41:52
-DMR Slot 2
3
00:00:02,000 --> 00:00:03,000
2016/02/17 16:41:54
-DMR Slot 2
4
00:00:03,000 --> 00:00:04,000
2016/02/17 16:41:57
+DMR Slot 2
5
00:00:04,000 --> 00:00:05,000
2016/02/17 16:42:24
-DMR Slot 2
The audio is very garbled. The DV1 manual says the discriminator output is active in FM mode, via the AUX output.
Any help?
G7VDI
Can .wav files be uploaded?
This file type is not on the list...
racingfan360
David,
If you upload a raw file up zippyshare then post a link to the url here.
>Hi, I am wondering why my setups are not displaying information such as the talkgroup numbers >whilst I am decoding local DMR systems?
I must admit, I am already a bit confused though. From the event file you post, it already shows the Talkgroup (eg TG=65485). You will have DCC from the Events Log window. You have the Slot number too eg Slot=1.
The bit that it is showing though is that the call is encrypted (Enc). The Event Log window will show if it is Basic Privacy or Enhanced Privacy. This would explain why the audio sounds garbled.
