DSDPlus Download files from RRDB
mwjones
Van Alstyne, TX
First, I got to say that I am very appreciative of the fact that @blantonl added the support for these downloads to more than just the P25 systems.
But, there is a bug, and it gives those downloads some problems - non valid characters are in the talkgroup names, and when you download the talkgroup file and append it to the running talkgroup file, DSDPlus will throw out pages of errors, requiring manual editing to clean them up.
First, is some talkgroups have quotation marks in their description, which DSDPlus will think is the end of the entry, and say that there is invalid data at the end of the line. So for instance if I look at the US Air Force System:
There are several instances of this, like:
Which when generated into a DSDPlus download looks like:
P25,BEE00.157,48021,50,Normal,0,0000/00/00 0:00,"[PSFB Sec 1] Security Police "Control""
The second variant is a non-standard character being embedded in the name - it may not show on the web interface, but will show up in the DSDPlus download. Looking at this system:
The descriptions in RRDB presentation look normal:
But the problem starts showing up in the download:
P25,BEE00.9C5,35723,50,Normal,0,0000/00/00 0:00,"[DMNS Sec] Security " P25,BEE00.9C5,35724,50,Normal,0,0000/00/00 0:00,"[DMNS SecTac2] Security Tac 2 " P25,BEE00.9C5,35725,50,Normal,0,0000/00/00 0:00,"[DMNS BldgOps] Building Operations " P25,BEE00.9C5,35726,50,Normal,0,0000/00/00 0:00,"[DMNS Group Tour] Group Tours " P25,BEE00.9C5,35727,50,Normal,0,0000/00/00 0:00,"[DMNS Fire Sys Mx] Fire System Maintenance" P25,BEE00.9C5,35729,50,Normal,0,0000/00/00 0:00,"[DMNS Bld MX] Building Maintenance " P25,BEE00.9C5,35736,50,Normal,0,0000/00/00 0:00,"[DMNS Ops] Operations " P25,BEE00.9C5,35737,50,Normal,0,0000/00/00 0:00,"[DMNS LifeSafety] Life Safety "
You'll notice those pesky little spaces at the end of the description - a simple space won't break DSDPlus, but those are actually what's called a Non-breaking Space or NBSP in web parlance (it's typically a piece of web code that says the words on either side of the space are not to be split between lines and should remain on a single line), and DSDPlus doesn't like them. I use Notepad++ for editing the files, and it highlights the invalid character when I was chasing it.
Since I don't know how the parser for generating these downloads works, I have no idea if this is something that can be fixed in flight, as part of generating the download, or if this is a fix that has to happen to the individual entries on each system. I also doubt that these two systems are the only ones with these issues.
mwjones
Van Alstyne, TX
@kurtswaney @abqscan
Just curious, on the Denver system, what are these, Â, that are listed on most tg's in Colorado Convention Center and Denver Museum of Nature and Science departments?
If you look at my screen capture in the first post, those entries on the Museum of Nature and Science with that  are the same place the Non-breaking space used to be, so it may be something @blantonl did to make them visible (I've been inside the aforementioned Colorado Convention Center all day, so I'm just now getting around to responding).
I will say though that they are not showing in the DSDPlus.groups downloads:
P25,BEE00.9C5,35723,50,Normal,0,0000/00/00 0:00,"[DMNS Sec] Security" P25,BEE00.9C5,35724,50,Normal,0,0000/00/00 0:00,"[DMNS SecTac2] Security Tac 2" P25,BEE00.9C5,35725,50,Normal,0,0000/00/00 0:00,"[DMNS BldgOps] Building Operations" P25,BEE00.9C5,35726,50,Normal,0,0000/00/00 0:00,"[DMNS Group Tour] Group Tours" P25,BEE00.9C5,35727,50,Normal,0,0000/00/00 0:00,"[DMNS Fire Sys Mx] Fire System Maintenance" P25,BEE00.9C5,35729,50,Normal,0,0000/00/00 0:00,"[DMNS Bld MX] Building Maintenance" P25,BEE00.9C5,35736,50,Normal,0,0000/00/00 0:00,"[DMNS Ops] Operations" P25,BEE00.9C5,35737,50,Normal,0,0000/00/00 0:00,"[DMNS LifeSafety] Life Safety"
GTR8000
NY/NJ Database Guy
BEE00
Hmm, the other day I renamed a trunked system in NY, it looked fine afterwards, but Sunday morning I noticed that  character in the system name. I re-edited it and it seems to have disappeared. Odd.
Unitrunker2
Unitrunker users are finding some hypens replaced with weird characters. The DB is currently down. I'll post examples once it comes back.
dave3825
Suffolk County NY
I reported a handful of the typos - including one category name in Florida - to the DB admins.
Thinking those are not actually typos. Database search of ’ appears on many different systems by different admins.
GTR8000
NY/NJ Database Guy
BEE00
Per Lindsay:
We did a database upgrade this weekend. It probably changed some character sets during the conversion.
There's really no point in reporting these via submission tickets, as it's a systemwide issue post-upgrade that Lindsay probably needs to fix en-masse.
GTR8000
NY/NJ Database Guy
BEE00
I think @GTR8000 just showed you his take on it, he is aware of it and I'm sure will make changes when he can, it may not be an easy fix, but he is aware of it.
I don't make those sort of fixes. I was merely suggesting that issues with character sets affect the entire database and should be looked at by Lindsay, not individual dbadmins.
Sorry for the misunderstanding, "his" meant Lindsey, I was just pointing out that you showed Lindsey was aware, not that you were fixing it.
