DSDPlus DSDPlus Fastlane Update V2.228 on 12/21/2019
mrc333777
Barberton, Ohio
the links and passwords changed. gotta wait for your email.
would be nice though if the mouse wheel or page up page down would work in the event window to scroll up the text
SignalPatcher
Good job ;)
Why is LineIn inactive?
How can I choose a card?
The system is correctly configured. The DSDPlus2p212 version works automatically.
rumcajs_tr
Europe, Czech Republic
The last FL update us not working for me also. Everything is mess.
Problem 1
No matter what I put in the command line, (-rv, -rp, -rc,...) it always tries to connect to TCP , even if I put -i2 to command line - it is ignored.
Problem 2
Is anyone running DSD+ with the SDR# DSD Interface plugin with any success? No matter what I use in the command line, to include -rp, it is defaulting to TCP.
Not working with SDR# plugin either. Connected to issue 1.
Problem 3
I tried to use DSDPlus without SDR#, but I failed... I can't even start FMPA - the widow displays error:
When I check the AirSpy S/N, using airspy_host_tools it is OK:
When I try to put this number into FMPA.cfg, it gives error again:
I am lost... any help???
KC1UA
Scan New England Janitor/Maintenance
Marstons Mills, Cape Cod, Massachusetts
I found a solution....totally missed the new menu in the event log even after I read about it in prior posts....DOH.
To make it work I did this:
1. In the event log Input menu I chose "Line 1 (Virtual Audio Cable)
2. In the same menu I also chose "Monitor Source Audio Always" as I pass analog audio through DSD+ via SDR# as well.
These setting appear to hold between sessions, so back in business.
rumcajs_tr
Hi, thanks, it is working. Prolems 1 and 2 solved then.
The problem 3 remaining... but I made some progress.
I found that the AIrSpy S/N must be entered in the first line of FMPA.cfg like this "26A464DC285E1993" an not like this "0x26A464DC285E1993".
Now I have another problem - error message "libfftw3f-3.dll is missing" ???
EDIT, OK, solved it by this help: DSD+ 2.71 Error
Now I have another problem.... will report back soon
rumcajs_tr
OK, now I have this problem, when I try to launch FMPA, these two windows pop-up:
When I press "cancel", the program quits, so I have to pres OK, however, after this, it gives me error:
and the program FMPA quits:
Any Ideas?
rumcajs_tr
Fine... coppied all the original files from dsdplus page, now I am back with AirSpy.dll on version 1.0.6, but getting this message:
and this in the cmd window
I got it working... had to use 32bit version of airspy.dll from airspy_host_tools , even though I have a 64bit machine and windows.
cyberwolfm636
Is there a new readme file somewhere i'm missing. I like reading text files that explain everything to me. I about had a heart attack when I went ahead and didn't back anything up like I should have and just over written all the files. I had a heck of a time getting it to work and discovered this thread after 100 hairs turned grey fighting with it.
cyberwolfm636
Good job ;)
This one got me too. Click on Control and pick Passive Digital Monitor. I re-opened DSD Plus afterwards and for me it saved. I also had to make a dsdplus.siteloader file for DSD+ to start. Once you do that, you can pick your source.
garys
Texas
I had the same thing for my frequencies file. Turns out that there were in fact three errors. The way I tracked it down was by loading the frequencies into Word and activating line counting. Fixed the errors and no more error message.
Saying there are a bunch of network id's missing from site loader . Worked fine yesterday. Also hitting l is not bringing up the loader for me. Have to play later.
garys
Texas
Never mind. I was staring right at the menu items and not recognizing them. Took me a while to get the audio working, but that turned out to be a Windows setting issue.
The only thing now is that I occasionally get "clicking" through the speakers when nothing is going on. I have Monitor Source Audio deselected.
That aside, audio processing seem improved, but maybe its my imagination.
I see an added function to lock out private call audio. Thanks!
I'm getting "Discarded WaveOut Block" messages. What does that mean?
druhe
Southwest Pa
For those of us (mainly me) that are not as DSD+ savvy, where is the event Input menu located ? I'm having the exact same problem that you described but I'm clueless. Thankful 2.212 was backed up
Thanks in Advance.
garys
Texas
The menu is at the top of the Event window. It's staring right at you, as it was me! :) It's just most of us are used to keyboard commands and aren't looking for a menu bar.
druhe
Southwest Pa
Well I'll be damned. So now that I see that, my first line is grayed out and won't allow me to make a change. I changed Monitor Source to always as suggested with no joy.
garys
Texas
I haven't got that far yet, so I can't advise you. I'm still playing with the other settings.
