ChrisBoden
Scientist, Author, Weirdo
Greetings everyone. I dearly hope someone here can prove I'm an idiot in five minutes with whatever stupid thing I'm overlooking.
I'm trying to listen to a P25 system in my local area. So, this is what I've done.
I watched the set of instructional videos made by SignalsEverywhere, located here.
Starting with a brand new legal installation and a empty (zero partitions level of clean) hard drive I setup a solid working laptop (I7 class CPU with 16GB of RAM). It's running Windows 10 with every update installed. No problems, works great.
I installed an RTL-SDR V3, by the book, done it many times, the usual Zadig, etc. Perfect.
I installed SDR# just to test and make certain everything is happy.
It's connected to a large dicone scanner antenna outside on a mast with a quality feedline, getting fantastic reception.
I pulled the RadioReference page relevant to my area, and checked both the control signal and the voice channels. Yup, great, clear signals right where they should be. The control signal is as it should be and tunes in great in SDR#.
I downloaded and installed DSDPlus as instructed in the videos, and purchased the fasttrack setup, extracted that by the book.
When I ran it, it was missing a dll file (libfftw3f-3.dll), so I found the original source for the missing DLL. It's here. http://www.fftw.org/install/windows.html
I wasn't certain which version it wanted, 34 (the software is 32) or 64 (my system is 64) so I tested both. 32 works fine, 64 throws an error, so there we go and that's solved.
I followed the instructions to the letter, several times.
The control signal shows up loud and clear in SDR#, but doesn't appear at all in DSDPlus, and as a result, nothing works.
I've been at this twelve hours.
Help?
Help?
