DSDPlus DSDPlus is missing the signal?
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Anyone using DSD-2268 ? I am looking at some 900mhz its showing DPMR but that's all! No data at all nothing?
Screenshot? Are you using FMP* + DSDPlus or SDR Software + virtual cable + DSDPlus? Do you have DPMR selected? In the menu system, under Decode, "Decode DPMR" is not selected automatically. You need to enable it. And I can't remember, but it _may_ be that if you enable DPMR deoding, you may not be able to decode any other protocol whilst you are decoding DPMR.
Mike
radioopperator
Have not tried disabling all the other flavors but did add DPMR. (ALSO) Tried running the DSDPLUSUI and when I try to add the FMP24.exe it says
not dsdfastlane? but the files are from their updates? and yes I have Virtual cable on computer even though I believe its no longer needed per DSD staff.
mtindor
OH/WV DB Admin
It is safe to assume that you paid for DSDPlus Fast Lane and are running the most recent version (not just the files that can be obtained from www.dsdplus.com). If you have the "free" version of DSDPlus from www.dsdplus.com and did not pay for / recieve / install DSDPlus Fast Lane, then you do not have Fast Lane.
If you do have Fast Lane, I cannot say why DSDPlusUI isn't working. It's not guaranteed to work. DSDPlusUI is not something made by the DSDPlus author. If it doesn't work you'll have to get support from the author of that software.
A Virtual Cable is not needed if:
a. you are running DSDPlus Fast Lane
b. You are running FMP* connecting to DSDPLus directly via direct method or TCP Linking
Mike
radioopperator
Yep I have DSDplus2268.exe and FMP24.exe and all the other files registered to me. I did play with the DSDPLSSUI last nite and in setup it says FMP24.exe NOT from dsdplus? and its all the latest versions that came with 2268. I did try disabling all data types except DPMR with no luck on a bunch of 900mhz commercial channels all with no luck?
BM82557
Berkeley Co WV
DSDPlusUI 1.01.37 is the current stable version, 2.0.9 is Beta status, which are you attempting to use?
DSDPlusUI 1.01.37 and DSDPlus 2.268 get along ok on my systems.
mtindor
OH/WV DB Admin
Whilst you are parked on an active 900 mhz trunked channel with DSDPlus, please consider using "r" in DSDPlus to record a minute of raw audio. Press "r" once when focused on DSDPlus and you will start raw audio recording. Press "r" again a minute later and it will stop recording. Then archive up that file make it available for us to download and run through DSDPlus ourselves.
You did say that when you have FMP24 + DSDPlus running, in the bottom lefthand corner of the DSDPlus EVent Window it does display DMPR right? If so, then it must be copying the signal. The question is, is the signal any good. That's why I'm asking that you consider recording some raw audio and making it available so that we can download it and pipe it thorugh our DSDPLus in an attempt to give you a better idea why you aren't hearing anything.
mike
radioopperator
mike
Ok Yes I can do a record there is several 900mhz commercial channels I (assume) part of a simulcast that all show DPMR with no data at all.
radioopperator
I tried it with the Beta not the stable version.
slicerwizard
Toronto, Ontario
Wouldn't be surprised if it's something else, probably DMR. Unless you're outside of North America, enabling dPMR detection is probably just going to cause you grief. Just about every digital signal is going to have 12-symbol sequences that look like dPMR sync patterns. And using something other than FMPA/FMPP/FMP24 is just going to exacerbate the problem.
But definitely cough up a raw audio recording so we can see what's up.
bobruzzo
W1AV
Cranston, Rhode Island
I got same error but I didnt have the patience to figure it out so back to using my .bat file!
radioopperator
I'm un the us the ones I believe I see are Los Angles? one seemed to have a beep in the data channel every so many seconds and others seemed close to P25? I will get a raw audio capture soon.
aaz
Horta - Azores
Hello everyone,
I am a fast lane user and I have the latest version.
Can someone help me with the command I have to use to view the basic privacy key number in the log?
Thank you very much
radioopperator
All you get is key (alias) and algorithm type ADP, AES ,DES
All us systems are slowly moving to OTAR! Or that's the plan?
  • Like
Reactions: aaz
aaz
Horta - Azores
BP key number appears without needed to enter anything for me.
If you are chasing the actual key, you won't find it as it isn't transmitted
This is the log, what could be wrong?
Thanks Kazzaw
aaz
Horta - Azores
Eh? BP does use key IDs.
Yep BP use key Ids. iI know that, the network in question uses BP. The problem is that Fast Lane does not show it .... :unsure:
please see the log, is it due to the TXI? (( Enc TXI Group call; TG=14 RID=254 Slot=1 Alg=BP 4s ))
Thanks Silicewizard(y)(y)(y)(y)
