DSDPlus DSDPlus not receiving audio
rocky28965
Otago, NZ
Wasn't exactly sure where to post this.
I have been using SDR Console with a RSPdx.
Decoding DMR with DSDPlus.
This has been working fine until today.
I was having a look around SDR Console to see what other features I could use.
In more options I spotted the Digital Decoder & Trunk Voice Following.
Thought I would give them a try.
Well, my old brain couldn't get either of them to work, so I cancelled them.
Now the DSDPlus will not receive/process any audio.
I have attached the audio settings below
audio input device #1 = 'CABLE Output (VB-Audio Virtual '
audio input device #2 = 'Line In (VIA HD Audio(Compatibl'
audio input device #3 = 'Microphone (VIA HD Audio(Compat'
audio output device #1 = 'Speakers (VIA HD Audio(Compatib'
audio output device #2 = 'SPDIF Interface (TX1) (VIA HD A'
audio output device #3 = 'Headphone (VIA HD Audio(Compati'
audio output device #4 = 'CABLE Input (VB-Audio Virtual C'
audio input device #1 (CABLE Output (VB-Audio Virtual ) initialized
audio output device #1 (Speakers (VIA HD Audio(Compatib) initialized
I'm just looking for the easiest way to get it working again.
dave3825
Suffolk County NY
I will be honest, I am not all that familiar with the free version as I have been using FastLane for the past few years and it does not use virtual cables. I would post screenshots of anything you can so others that are up and up on the public version can assist.
Whiskey3JMC
Surfer of the Delaware Valley Airwaves
Simulcastylvania, TE
Select:
Make sure the same is selected in SDR Console and that volume slider isn't muted
rocky28965
Otago, NZ
That is all correct, but the problem is with SDR Console.
I have tried SDRuno and it works fine there.
It will be a setting I have accidently changed somewhere.
rocky28965
Otago, NZ
Nothing at 40 but I can set it at 12 or even lower and it runs just fine.
Just won't go on N-FM at any setting.
I must have upset something when I was playing round with the addons.
I have even tried uninstalling & re-installing SDR Console, but it made no difference.
dave3825
Suffolk County NY
You have to use one of those uninstaller programs that uninstalls and deletes all traces of the program.
To be honest, I have been doing sdr for a long time and I downloaded sdr console and set it to output on my vac 9 and set my DSDPlus for the same and it would not populate DSDPlus. I could hear the control channel and also see signal in the vac cable. I will stick with Sdr#.
dave3825
Suffolk County NY
I mainly use DSDPlus with FMP24. The only time I use DSDPlus is when using the fast scanner in sdr# to locate new digital signals.
