dsdplus p25
mattnelson26
Hopkins, Minnesota
i am a fastlane subscriber. i am trying to trunk track ARMER P25 but when i get all fmp and vc up and running all i get is digital sound no voice. can anyone help me?
thanks,
matt
natedawg1604
Colorado
How many rtl dongles do you have? You need at least 1 dongle (if you also have a tapped scanner, otherwise you must have 2 dongles). Also, can you post a screenshot of whatever you've got running so far? You should have a voice and control channel instance of DSD+ running, along with a voice and control channel instance of FMP24.
mattnelson26
Hopkins, Minnesota
Yes i have 2 dongles. the first 2 pictures are of fmp24 cfg file and fmp24 error and the rest are of fmp cc.bat, cc.bat, fmp-cc.bat, vc.bat.
thanks,
matt
mattnelson26
Hopkins, Minnesota
more pictures
more pictures
adcockfred
Aldine, tx.
lower both gains with g key, widen that cc with b key and that might get your vc dsd to work and straighten out that cfg file
mattnelson26
Hopkins, Minnesota
Nope still not working. I have team viewer if you woild like to take a look. Also none of my talk group names or radio id are coming up.
Matt
adcockfred
Aldine, tx.
you are getting vc direction from fmp to get on right freq so that is good. but your cfg file is off . you don't look like your running fmp-24 on the screen
slicerwizard
Toronto, Ontario
You're running FMP instead of FMP24 with the Fast Lane version of DSD+. You should be using FMP24, especially since it looks like you're dealing with PSK signals.
You have the FMP24.cfg file open in Word? Have you been editing it with Word? Not a good idea. Notepad would be a better choice. And it looks like you've got blank lines at the top of the file. Also not good.
I'll take a stab at TeamViewer if no-one else offers to. RR handle at gmail.com to contact.
