dsdplus recording ??
OSCEOLA IOWA
hello,,i'm new to using sdr dongles and pc software as a scanner... but i'm running sdrsharp and the newest dsdplus from fast track...i'm decoding moto turbo and it works very well.. i'm wanting to record some of the audio... when i hit the (r) command to record... it records the dmr signal or tones.... how can i record the decoded audio that i am hearing... thanks 4 ur time....
cg
Connecticut
The "r" command is to record the raw audio. You need to set up the program through the startup command line or batch file to record the audio.
-Pwav or -Pmp3 is what you need to add. Details are in the help file.
chris
Spitfire8520
Might be slightly less clueless! =)
Colorado
Assuming that you haven't used the -O NUL command, it should be automatically recording everything to DSDPlus.wav. The -Pwav or -Pmp3 turns it into per-call recording which splits it into many different files if that is what you want.
