DSDPlus
tac7
Hamilton, ON
If -v4 doesn't give you talkgroups, then you are SOL. Try -v4 though.
Mike
Thanks -- with that switch the display showed "[E] Channel Group & User: tg=546" on every transmission, even though different TGs were active. I tried a tap off an analog and digital scanner with the same results, so it looks like I'm out of luck. Strange that with the regular DSD the correct TGs show up without a problem.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Is 8736 meaningful as a talkgroup ID to you?
In the RRDB, if you were to look at a 'decimal' talkgroup, you might see something like 16960, and then a hex value of 424. Well, 16960 really isn't the decimal equivalent of 424 hex. The decimal equivalent of 424 hex is decimal 1060. RRDB shows it as 1060+16 = 16960.
So you might see 546, which is decimal. Hex value would be 222, and RR decimal would be 8736.
222 (hex) = 546 (decimal) = 8736 (scanner-flawed decimal, which is what we display in RR).
There is a reason behind that. A sage once told me the whole story behing why 'decimal' on a scanner really isn't the decimal equivalent of a the hex counterpart. Blame it on a certain scanner manufacturer that it is that way :)
Mike
jcardani
Orlando, FL
Actually the reason it is that way makes perfect sense. It comes down to the handling of the 16 status bits (or t-bits) of a type II Smartnet Motorola talk group by the scanners. (The status bits handle patch, all group, emergency, encrypted, etc. status) With early scanners you needed to program the 0 status bit for regular talk group.
See:
Motorola Type II Smartnet - The RadioReference Wiki
Mike
jdobbs2001
I was able to download it from the megaupload site. use Firefox and it works, ie11 does not. Decoding mototrbo and nxdn48 with no problems.
foxy647130
East Cost
2 RTL and 2 Sdrsharp programes with Unitrunker help
Ok I will do my best here I have 2 RTL dongles set-up and 2 SDR Sharp programs running and I also have DSD+ for decoder. Now My control sdr folder has the trunker plugin and is taking tons of stuff off the Unitrunker
now the voice fold with sdr when I have the voice sdr running what Freq should it be set to. Why I ask is that the sdr control that is taking in the trunked signals jumps around like it should FREQ To FREQ I don't think I have the voice on set right because the DSD+ may show one if that voice decode in one hour as the control sdr is showing tones of stuff coming in. Sorry very new to this so sorry if it is confusing a little. In a nut shell I'm just trying to get the DSD+ to decode better heres a screen shot of the control data coming.
Thanks a bunch new member Foxy647130 AKA Johnny D.
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
You'll need 3 VAC running
one for the control ch decode
one for the line in to dsd+
and one for the dsd+ output
The 2nd receiver (sdr) will need the unitrunker plugin running.
some sdr and dsd+ tweaking may be needed after depending on the system you're monitoring.
foxy647130
East Cost
ok how to I setup the You'll need 3 VAC running
I have only 2 right now one for control and voice I will add another right now wich is easy but how do I setup for the dsd+ I know sdr on choose from the drop down boxes but not sure how to do it with DSD+
jasonhouk
Uniden AlphaMan
Marion, Ohio
Sent you a PM
foxy647130
East Cost
Sorry super new whats a PM. I just added another line so now I have three and I added the trunking plugin to my other sdr voice file now just the DSD+ I need help with PM HMMM I don't think I know how to get that or make it sorry
jasonhouk
Uniden AlphaMan
Marion, Ohio
A private message under RR forums. You should have 1
iw2dtt
pavia
DSD + ( -XR )
Hello
I found a good software but in the last edition ‘ –xr ’ control is missing
I’m referring to dsd+ version
I’m wondering if I haven’t seen it or it doesn’t exhist
Thanking you in advance for your reply
Best regards
br0adband
Springfield MO
Hello
Best regards
DSD+ automagically detects the polarity (?!?!) of the DMR/MOTOTRBO signal it's decoding and adjusts itself accordingly, the -xr switch is for DSD only (the older and original digital speech decoder) which could not do automatic inversion of the incoming signal.
DSD+ doesn't need such a switch, it's all done for you when you decode something.
ansul1001
#1 Member
Hesperia California
You need 2 lines
Line 2 to feed unitrunker and line 3 to feed dsd+
NDRADIONUT
FARGO ND
I cant get the download to work... Can someone send me the original zip file ?
