DSDPlus DSDPlusUI
hamradionl
@mtindor, this is offtopic but answer your remark
Its not the money, i live in Europe there we have tetra channels and my local area have: No trunk, No P25 fase I-II and Not any other digital mode is used for business coms. Receive 4x NXDN48/96 channels very small private rental network (4 -9 voice calls per day) so i dont need the use Fastlane extra's or refined supported functions and this is reason some of us still use DSD+free and this reason my interest for DSD standalone UI used with DSD+free edition. I did use raspberry Pi+ OP25 and i dont like the handle or comfort to monitor or scan channels.
Annunaki
I still think you should buy the fast lane version and show your support to the developers.
The public release is extremely old and limited.
hamradionl
@Annunaki
DSD FREE version using FMP a quick test seem working.
Future request,
- possible change font size, for older men :)
- Always on top ON/OFF
hamradionl
@Annunaki,
DSD+free FMP
AF volume is this for decoded audio output? And is this working? Because the AF volume not responding
Or function not implemented in FMP?
SCAN seem working and monitor my 4 channels :)
Annunaki
The program forwards key presses to the respective windows, for a list of what the various functions do you can check the text files for DSD+ and FMP. I will also start adding more precise hints to the buttons in the future.
Annunaki
So I have spent a bit more time looking at the Public release of DSD+ and it does NOT support the AF volume adjustment and many of the other button functions available in DSDPlusUI's DSD+ section (time to upgrade to the FL release IMO), However FMP does support the IF volume adjustment which is working fine with DSDPlusUI release 32.
DSD+ 1.101pt key legend
79942
FMP key legend
79943
hamradionl
In the tap to edit
File
OPEN
SCANLIST
I dont see FMP.ScanList <= used for scanning and Scan is working in DSDui
In the free/public zip are 2 files FMP.txt and DSDplus.txt both with command keys to use.
  • DSDPlus.txt
  • FMP.txt
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
In the tap to edit
File
OPEN
SCANLIST
the .scanlist functionality requires TCP linking. You can't TCP-link in 1.01. You need Fast Lane (so you can have FMP24, which supports TCP Linking and scanlists). Buy Fast Lane. You are beating a horse that has been dead, quartered and eaten a few years ago.
In previous posts the OP has already indicated that the UI is for Fast Lane. The OP also suggested that limited support has just been added for FMP, but that there are constraints on what can be done because FMP is outdated and doesn't do what FMP24 does.
Mike
Annunaki
Thanks for verifying what I assumed:cool:
You are most welcome :) but I will look into what @thewraith2008 suggested earlier because he does have a point.
I dont want people being put off or paranoid when using the program but I also dont want people abusing an un protected exe as you can understand.
mrc333777
Barberton, Ohio
you could always just to a check for the version of dsd that is being used and adjust the menus / keys to which ever version it is.
it would end the complaints about it. also, upx doesnt really hide anything as it can be decompressed with the -d option.
