DSP going to Full Time Encryption
Roach112683
Rehoboth Beach, DE
Where did you hear that from?
An email was sent to State Agencies that this was happening. The email was NOT marked as confidential.
But from the looks of it unless officers physically switch over from encryption mode to clear mode it looks like they might possibly be having encryption on all channels as the email stated to manually switch over when using the Command Channel and switch back when not so I'm not sure how this would effect other channels. So this might effectively render the entire system Encrypted.
de784
Delaware
Shame if it happens
Roach112683
Rehoboth Beach, DE
Yeah. I don't think it will effect agencies who don't use Command on a regular basis but DSP definitely.
I mean some might forget and you might only hear half the conversation. I currently hear that some nights mainly weekends after a certain time. Dispatch goes Encrypted and I only hear half the conversation but in the morning it changes back.
So I don't know what will happen with other agencies I just know they said to manually turn on and off encryption so...
de784
Delaware
In Sussex when a car in in enc mode s cmd tells them to switch there radio off enc
trailhiker73
Delaware
I am somewhat torn on this decision because I’m for officer safety and protecting personal information, but at the same time they already have the ability to switch to an encrypted talk group or flip the switch when needed on CMD. Anyhow, I think this leaves Newark and Milford as the only two agencies that can be monitored on either NCC or Kent Simulcast. There’s still a lot to monitor on this system, but this puts a damper on this hobby in Delaware.
Roach112683
Rehoboth Beach, DE
Agreed. But at least here in Sussex there's smaller agencies with their own TGs that don't use CMD to talk so those would probably be open channels however like I said I'm not sure how it's going to work. If they forget to flip back or just choose not to it could make everything encrypted.
I know I myself have personally heard Rehoboth PD on their Dispatch Channel doing VIP escorts when they have 2 encrypted Channels they could do that on...
hey
Lewes, Delaware
It’s to bad that my Unication G5 Can not do Motorola smartsZone and DES became I have the key code
Roach112683
Rehoboth Beach, DE
I confirmed this morning with a police chief
Yes but as I said since the email mentioned to state agencies using Command to switch encryption on manually it might effect other channels if they forget to turn it off or just intentionally don't turn it off.
chrishoerner
KC3KSJ
Frederica, Delaware
I wonder if this will effect DNR Channels as well, They sometimes monitor / use DSP dispatch channels as well. Does anyone know their reasoning for deciding to go full time ENC?
trailhiker73
Delaware
Since KENTCOM dispatches 16464 - SW DNREC, I am curious if that will be encrypted as well.
Roach112683
Rehoboth Beach, DE
As far as it was stated to State Agencies ONLY the Command Channels will be full time encrypted. that is N-CMD, K-CMD, and S-CMD
However if an officer forgets to or deliberately doesn't turn off their encryption after using Command then yes it could be. But the notification was specific to just those channels.
Hope that helps you.
Roach112683
Rehoboth Beach, DE
Thats what worries me. If other agencys are forced to have the ENC keys installed to monitor / interop with DSP, then why not use it too on their own talkgroups.
Encryption does not need to be activated to talk to or listen to those channels as the radio decrypts it automatically with the chip installed.
However, As stated DSP is wanting ALL traffic over Command to use encryption. So if an agency is simply monitoring they don't need to have their encryption on.
chrishoerner
KC3KSJ
Frederica, Delaware
I get that, I'm wondering if other agencys even have the encryption codes in the radios at this time. If they do not then now they will need loaded. Once they are loaded in the other agency's radios how long until they start using it as well. Maybe they arnt using it now because no one has bothered to load the keys. Now that DSP is forcing it im worried about a snowball effect.
