EFJ 5100ES Programming - Issues getting started
thorium
Just keyload with DES. I run all mine that way. 90 aftermarket keyload cable and a Moto 3011DX.
Thanks for the alternative, it was not on my radar.
My traffic is certainly not so sensitive 56-bit encryption wouldn’t suffice, but it looks like I’d still need to make an investment in hardware and would find myself 30-50% of the way to just buying the hardware to do AES 256-bit (KFD tool and cabling).
The practical man in me should probably do this, but the techie in me says I’ll just have to go all the way! :)
sfletc21
Alright so UPDATE:
I got ahold of a newer HP laptop running Windows 10. A 64bit machine
Still using PCConfigure 2.18.6
The driver is installed- FTDI21228
The radio is on.
All device settings are as set in the instructions from bluemax49ers.
Tried multiple baud rates and COM ports.
Still getting the same error "Communication problem during upload"
I'm pretty stumped...
chief21
Western NC (Summer); Tampa Bay FL (Winter)
This has been said previously, but I'll say it again. Most PCC versions are OLD and were designed to run on the PC's of their day. Try using an older, slower machine with 32-bit Windows. For whatever reason, some newer, 64-bit Windows machines will work, but most will not. I run several PCC versions on my 32-bit Windows desktop (and laptop) without issues.
mikedaly
Reno,NV
Thanks!
Now I just need to find someone with a KFDtool and cables that wants to make $100 to load a key on my 4 radios... or wait to the equipment is in stock and spend $300 on it for my own one time use.
Well worth the money spent on KFD will cost more with cables or make your own. Its almost a guarantee that the keys will fail or loose a key. So having a keyloader of your own is best
KD8GUA
Alright so UPDATE:
The radio is on.
I program 5100ES models all the time on Windows 10 64 bit. Use the fastest baud rate. PCC 2.18.x was made well after 64 bit OSs came into existence.
The key that I have found is to always use real serial ports when able to, or genuine EFJ USB cables. Sometimes all you need to do is restart the computer before a programming session.
DeoVindice
P25 Underground
5150 Level
I've found these radios to be very tolerant of varied programming PC parameters. Lately I'm using a Windows XP virtual machine running under Ubuntu with a USB filter for my FTDI cable. Works flawlessly.
KD8GUA
I just have Panasonic Toughbooks for programming. I don't bother with FTDI cables or anything else. Keep it simple!
gtaman
TACSAT
GALAXY 19 91.0° W
I use a CF-29 running windows XP and a KAWAMALL serial cable. No problems ever. Only thing is the radios with worn contacts.
AESFTW
Fultondale, AL
Thanks!
Highly suggest buying a KFDtool and modifying an XTS-5k hirose adapter. Although if you pay for postage both ways, I can load keys for you.
dfb8085
Cumming, Ga
I use a Bluemax serial cable with a usb to serial adapter. firmware 6.16.18 and PCConfigure 2.16.8 no problem . The problem I got is trying to figure out how to program convential P25 to use with my Hotspot. No matter where or what numbers I use ( even the hex values) either there's not enough spaces and will not take all the digits or some odd ball problem. can anyone please tell me what to put where.
DeoVindice
P25 Underground
5150 Level
I've found that the Call List function is limited to four digits. The group ID range function (not recalling the exact name and am out of state right now) is usable for caller ID with the longer DMR IDs. Are you having difficulty inputting your ID or other users'?
dfb8085
Cumming, Ga
Thanks for your reply. I finally discovered what it was. Two things under tools then preferences there is a check box that says use hex values. I unchecked that and everything cleared up except the fact that the radio always took the hex nac value under channels instead of dec value. I was working with someone and he set me straight. The NAC value 293 is a hex number. once I put it in the hex box all went ok. Never knew nac was a hex number
