ELGIN FIRE DEPARTMENT
heymoe1
Elgin, Illinois
Hello! Can someone help me out with getting all of the Elgin Fire Department frequencies and Talk Group numbers? I was feeding fine, then tried to make a change in LED function, now I'm not able to receive anything. The scanner seems to be visibly acting nothing, but no reception that I can hear!
Any help would be GREATLY appreciated!
Mike
RBMTS
Starcom System with Kane county site:
1 (1)026 (1A)Kane County - SimulcastKane, IL851.325851.4125851.6625852.4125852.9125853.4125853.625
853.9375a854.0875854.2875855.4875855.7375c856.7375a856.9875
1551 60f DElgin/S Elg FireFire: Dispatch (w/ S Elgin) Fire Dispatch
1552 610 TElgin Fire Ops 2Fire: Operations 2 (w/ S Elgin) Fire-Talk
1553 611 DElgin Fire Ops 3Fire: Operations 3 (w/ S Elgin) Fire-Talk
1554 612 DElgin Fire Ops 4Fire: Operations 4 (w/ S Elgin) Fire-Talk
1555 613 DElgin Fire Ops 5Fire: Operations 5 (w/ S Elgin) Fire-Talk
1556 614 DElgin Fire IMSFire: Incident Management System (IMS) Fire-Talk
1557 615 DElgin Fire TrainFire: Training Fire-Talk
1559 617 DElgin Fire DiveFire: Dive Team Operations Fire-Talk
1560 618 DElgin Fire TRTFire: Technical Rescue Team (TRT) Fire-Talk
1561 619 DElgin FireHazMatFire: Hazardous Materials (HazMat) Ops Fire-Talk
RBMTS
I noticed that Fire Dispatch is P2. Hopefully you are using a radio that will receive Phase II systems. If not, that might be why you are not hearing them any longer.
RBMTS
There is your answer. I'm looking at my SDS200 right now. 1551 is active showing P25P2. The PSR-500 is not capable of receiving Phase 2. That's why you aren't picking them up.
RBMTS
A 996P2 would also work for you in that area but knowing that there is greater simulcast problems in Cook and Dupage, it might be better to try to go with the SDS series if you can afford to.
RBMTS
I concur at the moment. They must have some users with older radios affiliating on the TG forcing it to phase 1 from time to time. It was P2 during the many times I was monitoring yesterday.
ilgrant
Chicago, IL
The change to Phase 2 on Elgin FD Dispatch just happened recently. If the 500 is Phane 1 only possible replacements are Uniden 996P2, 325P2 and Whistler WS 1080 and it's cousin GRE PSR 800.
RBMTS
You use the 325P2 correct? When a talk group is being received the display will show P25 for Phase 1 systems and PTx (0 or 1) for a Phase 2 system and what slot is being used. The T refers to TDMA.
ltginrage
Yes the 325p2. Do I have to press Function when there talking on a tg to see it? This I what I seen when someone was talking.
RBMTS
It has to be receiving a talk group. You need to have the proper screen view turned on to see that. It's all in the manual.
ltginrage
It was reciving that talkgroup when I took the picture. I'll take a look at the manual.
RoninJoliet
ILL
When your stopped on a TG press "Func + 6 and it will change your readout to see on the lower right either "dat=P25 or "pto-pt1 for PhaseII.....
ltginrage
Thanks RoninJoliet and RBMTS for your guys help. I figured it out. I just got to remeber what DAT, P25 means. And how to tell in the db.
ltginrage
PTO for Phase 1 P25 for Phase 2, what does DAT and LNK mean?
Also, Does "T" mean Phase 1 and "D" mean Phase 2 in the db?
