Enc
JR45
Kitchener ONt Canada
What s with all the ENC transmissions on the Cedarwoods Tower that do not show up in the trunk tracking mode.
I heard these in the conventional mode. (Guelph stuff does show up)
gary123
Probably OPP intell units. I have heard Guelph on the tower lots of times. try going to Id search and see if you get any TGids that way
JR45
I have tryed listening in the search mode. I have my truck tracking scanner in the search mode and another scanner in the conventional mode and I am hearing losts of ENC in conventional but not showing up in truck tracking mode even though it is in the seach mode.
Guelph PD is the exception
motomeso
Ontario
Fire up Trunk88 and see if you can figure out what TG's are running encryption.
gary123
im too far to get ceadarwoods well but i will try T88 to see if I can pick up anything. Is there a single conventional freq that is more active? How is the signal streanth compared to the trunking signal?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
There's your problem, you need a trunking scanner not a trucking scanner :lol:
Seriously, most of the newer scanners are designed to recognize an encrypted signal and skip over it.
If you're using a newer scanner to follow the trunking system, you might hear a quick blip of audio before it passes on. If you're using an older scanner or you're parking on the conventional channel then you will see the encrypted activity.
It's probably Guelph PS which is now running encryption.
motomeso
Ontario
This is the same guy that was sure that Waterloo Region was testing Provoice with ENC a few weeks back but yet he can't determine which agency was using ENC on the Cedarwoods site.
