Error connecting to socket
mhshighimpact
Cross Lanes, WV
The stream program I downloaded not an hour ago has problems connecting to your server's port. MP3 and Vorbis formats do not connect. Is this on the client side, or the server side? And if it is the client side, what could it be? The firewall on my dedicated system is turned off. I made sure to try the simple stuff first before asking.
It's on an infinite loop of reconnecting with no luck.
Thanks!
[EDIT]
While further inspecting the program, I noticed that there is no server IP or port specified for the icecast stream. I did an nslookup on your primary server and attempted to use the typical port for an icecast, but no luck. At least I noticed some upload packets that left my network going to the WAN.
GordonE
Scanner Radio App Developer
I'll send you the information you need to enter via PM.
