Error messages
cpetraglia
Fairfax, VA
First time I have seen this.
"System exception # 2" This is on a well received system. There are also no signal bars.
All other systems are fine. What does it mean?
cpetraglia
Fairfax, VA
After changing back and forth with Monitor Mode on or off, every time I turn it on is when I get the error. I have adjusted the squelch from off to full, it makes no difference. As long as I leave Monitor Mode off, the system continues to receive just fine. I am wondering if this has something to do with the latest FW update. I never noticed it before.
ffexpCP
wizard of odd
Michigan
If you installed new firmware, make sure you also have the newest PPS. I had problems with newer firmware / older pps.
cpetraglia
Fairfax, VA
I have the correct PPS. I am not 100% sure its the FW, but it's awful strange. I had my G4 since mid May and first I have had this problem. What it does is RX the system for around 30 seconds after enabling Monitor Mode and then pops up the error. The signal strength dies off and I cant get it back without disabling MM.
cpetraglia
Fairfax, VA
Still looking for an answer on "System exception # 2" I would hope Unication would know what it means.
cpetraglia
Fairfax, VA
Dave,
I don't have a picture.
The screen shows nothing else but "System Exception # 2" That's all it says. It cuts off the current system as in no signal. When I disable Monitor Mode it comes back fine.
How will a picture help?
I'll try and get you one.
Thanks,
Chuck
cpetraglia
Fairfax, VA
Dave,
I just created the error twice in a row. It only stays on the screen for a second and a half at most. The screen goes back to scanning looking for a CC. Wont find one until MM is shut off. I cant keep the error up long enough to snap a picture. I can try to take a video, but it will probably be too big to email. I can't predict exactly when it will pop up.
cpetraglia
Fairfax, VA
FYI I reverted to the last PPS and FW and still does the same thing.
I have tried R11J and R11N2.
This only happens with one particular system. Wash. DC P25 PII. They still broadcast FD dispatch on Phase 1. It does not happen with three other adjacent PII systems. I suspect it has something to do with DC. Having a definition of the error would help.
ResQguy
Meh
Are you saying you are monitoring system 445 in monitor mode? This is full of encryption and phase 2 talkgroups, plenty of reasons to throw errors. Maybe 25% of this system is in the clear and phase 1.
cpetraglia
Fairfax, VA
Yes I am. However I also monitor Loudoun, Prince William and Prince Georges. All are Phase II systems which work fine in monitor mode. All have TGs that are still Phase I and in the clear. This is not that big a deal, I just want to know what the error is pointing to.
cpetraglia
Fairfax, VA
To be sure, this is not meant in any way to be a Unication basher. I love the radio and promote them all the time. Here is how I see it. The FW code writers had to write this error into the code or it would not show up. Therefore it clearly has a meaning.
phirephoto
Fremont, CA
Not really. You CAN program the application / firmware to pass on the error. They didn't necessarily write "Error 32" for example, but that may be whatever language they wrote the firmware in passing on an error.
For example, I worked at a software company a LONG time ago (early 90's). We stored a particular data in a text file, comma deliminated.
An error started creeping up - thank you ADD, I remember the error - "Input past end of file."
What did this mean? It means the program expected the file to end after a certain place, but somehow a 'blank' line was inserted at the end of the file, and since that line didn't have data, it was unexpected. We didn't 'write' "Input past end of file", but the programming language threw the error since we basically said "Display whatever error comes up."
cpetraglia
Fairfax, VA
That makes sense. So there may not be an actual definition of this error. I tend to use monitor mode to discover P1 and non-encrypted TGs so I then can enter them into the list. For example: The PG County system has everything listed as 'D' in the RR database which is clearly incorrect. I guess at this point I wait for the PII update and see how it all goes.
ffexpCP
wizard of odd
Michigan
What does this mean? LED on the charger displays a rainbow of colors.
