EX600 XLS Scanning
tkaplan501
Croton-On-Hudson, NY
Hello,
I have a Moto EX600XLS Portable Radio. Right now, when I am in a certain bank, when I go into scan mode, it scans all banks. For example when I am in my EMS bank, I receive stuff on my Fire channels. How do I make it so the radio only scans the channels in the current bank?
KG4INW
Midlothian, VA
It scans whatever scan list is associated with whatever particular channel you happen to be on. The scan list appears to be setup to scan channels from another zone. Lists can be programmed to scan whatever you want them to.
Do you have a Scan List Program setting in the menu? If not, you'll have to use the CPS to program your list(s).
tkaplan501
Yeah, I have CPS and I use it to program it, however some channels that are in my fire bank are also in my EMS bank. The dispatch channel is the same for both fire and EMS. However my town's EMS and Fire depts. have different ops channels, that I want separated. When I scan my EMS bank, I don't want my fire channel to open. How should I arrange my scan list's so this can work? Is there a bank scan mode? where it only scans the bank?
evfd1625
Indiana
You have to create a scan list for each channel. Go to the scan list part of the tree, make a new list, go to your channel where you input all the frequency stuff, go to the scan tab and change the list number too the new one you made.
Sent from my SM-N900V using Tapatalk
KG4INW
Midlothian, VA
Well, there is no explicit zone scan mode, per se. What you can do is have one scan list tied to your Fire zone (e.g. Scan List 1) that only contains channels you want to be scanning then and have a second scan list tied to your EMS zone (e.g. Scan List 2) that only scans those channels.
From the Tree in CPS, go to Scan, create two separate lists as described above then go to the Conventional Personalities. On your Fire channels, assign their scan lists to your Fire list and on your EMS channels, assign their scan lists to the second list.
HTH
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Tommy,
You mentioned that your dispatch channel is common to both fire and ems. You may have to create two identical personalities for that. Assign one of them to your Fire scan list and the other to your EMS scan list. You'll have to name them so you know which is which; something like DISP F and DISP E.
Then you just select whichever you're working, and the radio uses the desired scan list.
There may be a simpler or better way to do this, but this should work pretty well. If anyone has another idea, we're all ears.
