ProScan: Export Problem
brendan3
Southern California
Within a favorites list I have QK set for the department to D1 however D2 is what is actually imported as confirmed by sentinel and turning on the radio after import?
ProScan
Software Provider
Ontario, Calif.
In pro scan under the status tab system 1 is checked
I write to scanner
I turn on scanner
Scanner has favorites 1 on but system QK is a * or off.
I read from scanner into pro scan and it also shows system 1 QK as being turned off.
System 1 QK status does not seem to write.
This began to happen after the favorites lists were moved in pro scan so maybe that corrupted something?
I found a problem. It didn't have anything with dragging nodes around but involved writing to and reading from the scanner. Fix will be in the next release.
