Pro-668: Faster copying to scanner?
Circa
OH/PA/WV
It currently takes about 30 minutes to Copy from scanner, update, Copy Database to Scanner, update data in iScan software, then copy everything back to the scanner.
It seems to be very slow to copy data back to the scanner's SD card.
I'm running on an SSD and I have a UHS-1 sdcard in the scanner.
I was thinking about messing with the COM port's Port Settings in the device manager, but I'm not sure if that will even do anything.
Has anyone found any way to speed up the "Copying to Scanner" process?
marksmith
Anne Arundel County, MD
Put the card in a card reader and plug it into your pc. Takes a minute instead of 30.
Still need to connect for firmware updates, but database stuff is real fast.
WS1095/536/436/996P2/HP1e/HP2e/996XT/325P2/396XT/PRO668/PSR800/PRO652
